Sinusbot Installer Script
Debian 11, minimale installation:
Starting the installer now!
Detected latest TS3-Client version as 3.5.6
Reading package lists... Done
Building dependency tree... Done
ntp is already the newest version (1:4.2.8p15+dfsg-1).
Packages installed!
Failed to set ntp: NTP not supported
Command which failed was: "      timedatectl set-ntp yes". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 686.
Gibt es eine Lösung für dieses Problem? Außer Debian 10 zu installieren. Da es dafür keinen Support mehr seitens meines Anbieters gibt, und Debian 12 vom Installer nicht unterstützt wird, wäre ich sehr dankbar für eine funktionierende Lösung!
Packages installed!
Kannst einfach mein Script nutzen.
https://forum.sinusbot.com/threads/ubuntu-20-04-debian-11-sinusbot-installer-fixed-yt-dlp.8779/
sürekli hata veriyor lütfen bana hangi işletim sistemi ve versonunda iyi calısır ve sinusbotu acınca ts gırmıyor bide youtube dl hatası olmasın
Traceback (most recent call last):
File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/bin/youtube-dl/__main__.py", line 14, in <module>
File "/usr/local/bin/youtube-dl/yt_dlp/__init__.py", line 5, in <module>
ImportError: You are using an unsupported version of Python. Only Python versions 3.8 and above are supported by yt-dlp
Command which failed was: " youtube-dl -U --restrict-filename". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 957.
Her şey benim için mükemmel çalışıyor. Hangi işletim sistemini kullanıyorsunuz?
Ve sunucunuz yeniden yüklendi ve güncellendi mi?
