TS5 Question
Yes you can!
The reason is, there is nothing as a "TeamSpeak 5 Server". There is just a TS5 client currentlich in beta. But the server version is still 3.11.0 by now.
Both clients (TS3 and TS5) will be connecting to the same server.
So in the far future SinusBot will most likely still connecting to a server via the classic TS3 client, where assumingly all clients are using the TS5 client.
Ukaros
Yes you can!
yes and no. if we're talking about the free servers that come with TS5, it is currently not possible to connect TS3 clients to a TS5 server.
The limitation that only TS5-clients can join, is due to those free servers tied to the beta program (minimum_client_version). You could set that value also on your private server.
But technically there is nothing such as "TS5 server".
Ukaros
thats why i said currently;)
and who knows, maybe they will keep it like that to "force" users to use TS5
fabm3n
Tier II
Tier I
