Version: 1.0.0-beta.10-202ee4d
2021/05/15 10:44:01 c18ead1f INFO Loading instances
2021/05/15 10:44:01 c18ead1f INFO Loading instance://e9da1182-9da2-45 9e-ab5e-64efe3e2c7ae
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG Spawning instance shortly due to mi ssing configuration file.
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG Prespawn.
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG About to run.
2021/05/15 10:44:01 c18ead1f e9da1182 INFO Starting instance ts3server://127.0 .0.1?port=9988&nickname=SinusBot&password=&channel=&channelpassword=
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG executing script sinusbot-commands
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG executing script command
2021/05/15 10:44:01 c18ead1f e9da1182 INFO Initialization complete
2021/05/15 10:44:01 c18ead1f e9da1182 INFO Auto-Starting c18ead1f-1752-4158-9b cd-daa7d31e97c8/e9da1182-9da2-459e-ab5e-64efe3e2c7ae in 500 ms...
2021/05/15 10:44:01 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: L GPL version 2.1 or later; 81 codecs
2021/05/15 10:44:01 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2021/05/15 10:44:01 [GENERAL/YTDL ] INFO youtube-dl checking...
2021/05/15 10:44:01 c18ead1f e9da1182 PLUGIN [sinusbot-commands:86:12] Loaded Si nusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG registered callback for event load
2021/05/15 10:44:01 c18ead1f e9da1182 INFO script sinusbot-commands loaded
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG registered callback for event chat
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG module registered as command
2021/05/15 10:44:01 c18ead1f e9da1182 INFO script command loaded
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG resolving module command
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG imported module: command
2021/05/15 10:44:01 c18ead1f e9da1182 INFO TSClient quit. LogLevel has been in creased, please try to connect again to see more details.
2021/05/15 10:44:01 c18ead1f e9da1182 DEBUG Closed.
2021/05/15 10:44:02 c18ead1f e9da1182 DEBUG closing channels
2021/05/15 10:44:02 c18ead1f e9da1182 DEBUG About to run.
2021/05/15 10:44:02 c18ead1f e9da1182 INFO Starting instance ts3server://127.0 .0.1?port=9988&nickname=SinusBot&password=&channel=&channelpassword=
2021/05/15 10:44:02 c18ead1f e9da1182 WARN Fail from voice reader: read unix @ ->@: use of closed network connection
2021/05/15 10:44:02 read unix @->@: use of closed network connection . 138
. 508
. 514
. 489
. 532
. 2197
2021/05/15 10:44:02 c18ead1f e9da1182 WARN Fail from voice reader: read unix @ ->@: read: bad file descriptor
2021/05/15 10:44:02 read unix @->@: read: bad file descriptor . 138
. 508
. 514
. 489
. 532
. 2197
2021/05/15 10:44:02 c18ead1f e9da1182 INFO TSClient quit. LogLevel has been in creased, please try to connect again to see more details.
2021/05/15 10:44:02 c18ead1f e9da1182 DEBUG Closed.
2021/05/15 10:44:02 [GENERAL/YTDL ] INFO youtube-dl version compatible, supp ort enabled
2021/05/15 10:44:02 [GENERAL/!!!!!!!] NOTICE You may now configure and launch th e bots from the webinterface. http://0.0.0.0:8087
2021/05/15 10:44:02 [GENERAL/RADIO ] INFO RadioStation data loaded
2021/05/15 10:44:03 [GENERAL/RADIO ] INFO Imported radio stations
2021/05/15 10:44:03 c18ead1f e9da1182 DEBUG closing channels
2021/05/15 10:44:31 c18ead1f e9da1182 DEBUG Storing configuration.
