Natively no, spotify doesn't have support, but as @scheissegalo wrote, there are some scripts.@flyth with the upcoming changes, is there any way to make spotify working with sinusbot engine ? or there is no support base for that
Thank you for your answer, but I talked about a Windows version
Till ne official version is released you can use this: https://hub.docker.com/r/ochinchinsan/sinusbotHi, could you update the sinusbot docker image? thank you
[[email protected]p test]# ./sinusbot
./sinusbot: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by ./sinusbot)
./sinusbot: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by ./sinusbot)
./sinusbot: /lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./sinusbot)
./sinusbot: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by ./sinusbot)
./sinusbot: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./sinusbot)
./sinusbot: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by /root/test/libavfilter.so.8)
./sinusbot: /lib64/libc.so.6: version `GLIBC_2.27' not found (required by /root/test/libavformat.so.59)
./sinusbot: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /root/test/libavformat.so.59)
./sinusbot: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by /root/test/libavcodec.so.59)
./sinusbot: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /root/test/libavutil.so.57)
Had the same problem with Ubuntu 18 you need to Update your distro for safety to the newest one because glibc is not Supported on the older versions that fixed it for me so use a newer distro i also tried to get around this but nothing fixed it except for upgrading@flyth CentOS 7.6:
[[email protected] test]# ./sinusbot ./sinusbot: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by ./sinusbot) ./sinusbot: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by ./sinusbot) ./sinusbot: /lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./sinusbot) ./sinusbot: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by ./sinusbot) ./sinusbot: /lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./sinusbot) ./sinusbot: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by /root/test/libavfilter.so.8) ./sinusbot: /lib64/libc.so.6: version `GLIBC_2.27' not found (required by /root/test/libavformat.so.59) ./sinusbot: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /root/test/libavformat.so.59) ./sinusbot: /lib64/libm.so.6: version `GLIBC_2.27' not found (required by /root/test/libavcodec.so.59) ./sinusbot: /lib64/libc.so.6: version `GLIBC_2.28' not found (required by /root/test/libavutil.so.57)
Do you know which distros support this version? I tested with Ubuntu 22.04 and there was no problem.Had the same problem with Ubuntu 18 you need to Update your distro for safety to the newest one because glibc is not Supported on the older versions that fixed it for me so use a newer distro i also tried to get around this but nothing fixed it except for upgrading
As you used an older version of centos in the upper post i think the newest CentOS should work and yeah i also use ubuntu 22.04 works fine probably the older versions dont support the newest glibcDo you know which distros support this version? I tested with Ubuntu 22.04 and there was no problem.
@flyth You should look at this and make a patch for it. Or you can publish open source of the old version of the current stabil version so we can edit it.As you used an older version of centos in the upper post i think the newest CentOS should work and yeah i also use ubuntu 22.04 works fine probably the older versions dont support the newest glibc
