VPS HOSTING
flynns82
Someone could suggest a vps kvm stable host, I changed 3 host and it always happened that at least 2 times a month crashed and lagged.
I would need a stable host with no problems (or few: D), preferably low cost and with servers in italy or close to the Italy.
Thanks so much!
Thanks so much!
Try OVH. Should be the best price for KVM / reserved ressources.
Other option: Leaseweb (but never tried the musicbot there just my monitoring is running in there cloud)
Kajeczko
From myself I will suggest to put sinusbot to docker container, if it will run not properly (high CPU usage or RAM consumption, due to some bugs) the damage can be limited.
