was für comanndeline in ts oder in root server selber
ja is richtig hab aba das alpa insterlierrt udn kann uber sinusbot interface die plugins nicht runterladen es sagt es is runtergeladen aba nix in der liste is
- Kernel: Linux 3.16.0-7-amd64 x86_64
- Load Average: 0.37 0.54 0.51
- Uptime: 1 days, 17 hours, 14 minutes, 2 seconds
- OS APT Last Update: 03.03.2019 18:13:48 CET +01:00:00
- DNS resolution check:
www.sinusbot.com resolved to 104.28.14.74 -> OK
- HTTPS check with IPv4 mode: SUCCESS [Connection was established to
www.sinusbot.com, CODE #200]
CPU(s): 10
Thread(s) per core: 1
Core(s) per socket: 10
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
CPU MHz: 2199.998
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 1.02 GB/59.10 GB in use (1%)
- DISK: 17.54 GB/1.53 TB in use (1%)
+ libglib: 2.42.1-1+b12.42.1-1+b1
- Status: running (PIDs: 18521 18520, User: sinusbot)
- Binary Info: MD5 Hash: cc7e9b1c61045377b221302a86be605e, Perms: 755, User: root
- Version: 1.0.0-alpha.6-a47ac17
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.03.01)
- Time (local): 03.03.2019 18:20:18 CET +01:00:00
- Time (remote): 03.03.2019 18:20:18 CET +01:00:00
- TeamSpeak 3 Version: 3.2.3
- youtube-dl Version: 2019.03.01
- DiagScript Version: 0.7.1
[/CODE]
in the forum within a CODE-tag
