xNS91
Guten Abend,
habe das Problem das der Bot keine yt links abspielt. Es kommt die Meldung "streaming" jedoch hört man nix und im Webinterface läuft auch die Musik nicht ab. Woran kann das liegen?
Liebe Grüße
 - Operating System: Debian GNU/Linux 9.11 (stretch)
 - Kernel: Linux 4.9.0-7-amd64 x86_64
 - Load Average: 1.16 0.61 0.37
 - Uptime: 1 days, 22 hours, 12 minutes, 17 seconds
 - OS APT Last Update: 11.12.2019 04:43:57 UTC +00:00:00
 - Shell Locale: en_US.UTF-8
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            QEMU Virtual CPU version 2.5+
    CPU MHz:               2599.998
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 389.62 MB/492.37 MB in use (79%)
 - DISK: 1.64 GB/9.81 GB in use (16%)
   - libglib: 2.50.3-2+deb9u1
 - Status: running (PIDs: 8365 8363, User: sinusbot)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.11.28)
 - Installed scripts: advertising.js; alonemode.js; Animated_Nickname.js; Auto_Channel_Creator.js; bookmark.js; command.js; followme.js; Lauftext__Ticker__APINewsticker_Support.js; norecording.js; Private_Channel_Manager.js; RankCSGO.js; rememberChannel.js; Tunakills_Rankingsystem.js; welcome.js; Youtube_Search.js; YT-search.js
    linux-vdso.so.1 (0x00007ffee51b1000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f06ea78f000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f06ea437000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f06ea036000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f06e96d1000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f06e945d000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f06e9259000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f06e8f55000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f06e8d38000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f06e89b6000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f06e879f000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f06e8400000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f06e81e6000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f06e7fde000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f06ea9a9000)
 - Time (local): 11.12.2019 17:31:02 UTC +00:00:00
 - Timezone: Etc/UTC
 - TeamSpeak3 Version: 3.3.2
 - youtube-dl Version: 2019.11.28
==========================================================Liebe Grüße
