Wenn ich den Bot starten will kommt nur diese Fehler meldung
Could not find TeamSpeak 3 Client: stat /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: no such file or directory
Mein Server ist ein VServer
System ist Debian 10
- Kernel: Linux 4.19.0-9-amd64 x86_64
- Load Average: 0.02 0.03 0.00
- Uptime: 0 days, 1 hours, 44 minutes, 48 seconds
- OS APT Last Update: 30.06.2020 19:44:24 CEST +02:00:00
- Shell Locale: de_DE.UTF-8
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
CPU MHz: 4008.004
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 374.56 MB/3.81 GB in use (9%)
- SWAP: 0 B/3.95 GB in use (0%)
- DISK: 2.98 GB/35.22 GB in use (8%)
- libglib: 2.58.3-2+deb10u2
- Binary: /opt/ts3soundboard/sinusbot
- Binary Info: MD5 Hash: 224b687db910b732fe5a7cfec4f6c78e, Perms: 775, User: sinusbot
- TS3 Plugin: unknown (TS3client not found)
- Bot Plugin: unknown
- TS3 Client: unknown
- LogLevel =
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (TS3client-binary does not exist!)
- YoutubeDLPath = not set
- TS3Client/libqxcb-glx-integration.so:
linux-vdso.so.1 (0x00007fff749ba000)
libswresample.so.2 => /opt/ts3soundboard/libswresample.so.2 (0x00007f7e497ae000)
libavfilter.so.6 => /opt/ts3soundboard/libavfilter.so.6 (0x00007f7e49456000)
libavformat.so.57 => /opt/ts3soundboard/libavformat.so.57 (0x00007f7e49055000)
libavcodec.so.57 => /opt/ts3soundboard/libavcodec.so.57 (0x00007f7e486f0000)
libavutil.so.55 => /opt/ts3soundboard/libavutil.so.55 (0x00007f7e4847c000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7e48470000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7e482eb000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7e482ca000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7e48146000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7e4812c000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7e47f6b000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f7e47d4d000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f7e47d41000)
/lib64/ld-linux-x86-64.so.2 (0x00007f7e499ca000)
- Time (local): 30.06.2020 21:33:00 CEST +02:00:00
- Time (remote): 30.06.2020 21:33:00 CEST +02:00:00
- TeamSpeak3 Version: unknown
- youtube-dl Version: unknown
CPU(s): 1
Socket(s): 1
CPU MHz: 4008.004
- LogLevel =
