No Radios
DesertFade
Operating System: Linux
SinusBot Version: 0.11.0 (newest)
TS3 Version: 3.1.6 (client) and 3.0.13.8 (server)
There are simple no radio programs. If i go to the Radio-Tab, i only get the text "Nothing found."
YTDownloader and playing music does work normally, so i dont think it's a firewall/internet-connection problem.
Is the API (xiph.org) the guilty one?
There are no errors in the instance-log and bot-log.
THE DIAGNOSTIC-TOOL DIDNT HELP. (ALSO NOT UP-TO-DATE)
Did you just install the bot? As I had to re-install the bot due to a VPS error that resulted in a restoring a backup that was before the bot installation.
Thing is, the Radio tab had all the radios before the re-installation, maybe the API is broken?
I just installed the new version and i didn't upload any backup(s). I also did a reinstall from my vServer, so i dont think there is any incompatibility (debian 8.0, also all dependencies)
Yeah, i had all radios before the re-installation, so i think the API or something with the new version is broken.
Greetings
(please write in german language if you are german ;D)
Yep I suspect it's either the new version or the API has broke itself, wouldn't be a problem if I could figure out how to get a radio streams direct url/ip thing.
I am running:
OS: Linux - CentOS 7
SinusBot Version: 0.11.0-8e5f1a2
TS3 Client: 3.1.6
TS3 Server: 3.0.13.8
So I doubt it is an isolated issue with just your system.
i dont think it is a problem from my server. As i said, it worked well everytime after a reinstall of my OS. it happend the first the after many reinstalls, so i think it isnt my fault.
The log also doesn't say anything what could help me.. :/
do you gut any more solutions?
could i check if the API is down?
greetings
I've got no clue, think we just have to wait for a fix or something, as I said, it worked for before, which was an installation a few days ago but my VPS stuffed up today and had to re-install the Bot and now it is doing this 'Nothing Found' problem.
I will keep searching to see how to get a radio streams direct IP thing, at least that way we can add the radio's we want directly until this is fixed.
ahhh okey, you got the same problem. i just thought i'm the only one.^^
Yes, i added some radio streams with the URL, so i atleast have some of them.
Hope they release a update as soon as possible, im waiting yearningly for it.
I like to try out some radios.^^
Greetings
Yep much easier when a heap of radio streams are already added :p
Also, how did you add some radio streams? Did you have to look for a specific url? as many I try do not work :(
EDIT* Managed to get one to work : http://listen.radionomy.com/-top20-radio : was the main one I was using in the radio stream list due to not being able to add the one I want.
google as example: "iloveradio stream url"
From this found websites, there is always a site who display the stream url.
greetings
Yeah that's how I managed to find the one I found, Had to go to a specific URL and then inspect it to find url.
I've tried this with the one I want to add, even tried inspecting, but I suspect they have it set up so you can't "steal" the link, oh well this one will do :)
Let's hope they fix this bug soon so we can get other radio streams easily.
Could you please check the log for messages containing GENERAL/RADIO and whether there's a radio.json inside your data directory?
Hey flyth,
Just checked the directory of the sinusbot and I could not locate any radio.json, I did a search as well and found nothing.
As for the log, I set it to 10 (not sure if I was suppose to do this) and there's nothing saying GENERAL/RADIO.
I am guessing it's because there is no radio.json.
Note: I used the auto installer by Qhiliqq, could it be due to his install script?
Okay, strange. I'll have a closer look. Thanks for reporting!
@flyth, there is really no radio.json, i checked it too and i didnt find this file.
I can check later, if there is any message in the log containing GENERAL/RADIO, but at the last time (i checked yesterday evening), there was nothing about this keyword(s).
Could i just insert this file from an older download of sinusbot?
@KosmicReeds, i installed the musicbot without an installer.
Greetings
It's a problem with the original XML, I'll contact them about it.
For the time being, you can add/replace this to your config.ini:
URL = "https://www.sinusbot.com/yp.xml"
Note, that I will remove it once the original service will work again. Then you should remove that lines again as well.
Thanks, @flyth! It's working right now.
Radios are getting displayed!
Will you update the SinusBot-Beta or how do you announce the fix for the radios, so i can punctual remove the line/url?
Greetings
I'll try to post here once it can be removed, hopefully soon.
