No Radios
Tripps
I'll try to post here once it can be removed, hopefully soon.
Any update on this, I still can't find my radio stations sadly. I tried the url, but it isn't showing anything and by default it didn't have a url for me (sorry if I am posting on another thread instead of my own).
Tiikoo
I'v got the Porblem too,
But i can not fix it. I already have installed the Code from you, but i doesn't works ;c
Please Help! <3
Xenon
seitdem ich Sinusbot auf meinem (linux) vServer neu installiert habt, findet er keine Radios mehr,
weiß jemand woran das liegen kann?
mfg
wonderbra
Servus, wie es der Name schon sagt, findet der Bot kein Radio
Ich gebe zb ilove ein da kommt einfach mal nichts
auch Technobase etc .. gar nichts
Ich versuche die URL's von den Streams anzugeben klappt trdm nicht da er sie nicht downloaden tuet
auf der neusten Version ist es
was kann ich machen?
Nussi1986
It's a problem with the original XML, I'll contact them about it.
For the time being, you can add/replace this to your config.ini:
URL = "https://www.sinusbot.com/yp.xml"
Note, that I will remove it once the original service will work again. Then you should remove that lines again as well.
No Radios, i changed this in the config and restarted the Bot but still no Radios.
Technik
I made my Sinusbot instansen and then I wanted to go but the radio is not all funkzeinirt except for the radio ...
Pls help me
