Sinusbot Installer Script
Yah, I use script installer after that I copy paste the existing url on sinusbot installer, after sinusbot finished in install arises can not read password on sinusbot And I do not use caps at the time of sinusbot installer
Which OS do you use?
Tested it a minute ago on debian 8 and ubuntu 14.04 without your problem.
There is a huge error, i can't install it with centos 7 in any server or vps
100%[==============================================================================================================================>] 27.470 --.-K/s en 0s
2017-04-27 23:35:14 (74,4 MB/s) - escritos a stdout [27470/27470]
This is the automatic installer for latest Sinusbot. USE AT YOUR OWN RISK!
You can choose between installing, upgrading and removing the Sinusbot.
You're using Installer 1.3.4
What should the Installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Installing redhat-lsb! Please wait.
El paquete redhat-lsb-4.1-27.el7.centos.1.x86_64 ya se encuentra instalado con su versión más reciente
Done!
cat: /etc/debian_version: No existe el fichero o el directorio
/dev/fd/63: línea 257: [: ==: se esperaba un operador unario
Which start script should be used? system.d is prefered since Debian 8.
1) system.d
2) init.d
#? 1
1) Automatic
2) Own path
3) Quit
#? 1
Sinusbot isn't installed yet. Installer goes on.
This Sinusbot version is only for private use! Accept?
1) No
2) Yes
#? 2
Update the system packages to the latest version? Recommended, as otherwise dependencies might break! Option "No" = Exit
1) Yes
2) Try without
3) No
#? 1
Start installer now!
This could take a while. Please give it up to 10 minutes!
Installing necessary packages! Please wait...
[root@ns3063005 ~]#
Running hooks in /etc/ca-certificates/update.d....done.
Packages installed!
ls: cannot access /opt/sinusbot: No such file or directory
/dev/fd/63: line 622: kill: root: arguments must be process or job IDs
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
1) system.d
2) init.d
#? 1
1) Automatic
2) Own path
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) Try without
3) No
#? 1
[root@ns3063005 ~]#
I'll fix that witch CentOS.
Im using CentOS 7 and I cant installing packages I have tried by the URL: "bash <(wget O --no-check-certificate 'https://sinusbot-installer.de/download.php?s=27a9e3ed6558584d75c1c3fa294d4ce2&t=1493442266')" and the script in the website (sinusbot_installer.sh) He tell me to wait 10 minutes and after 5 seconds he explode and put me back on prompt.
Print: http://i.imgur.com/nhLkyJe.png
Any idea? Best Regards.
Then there must be an error. I'll try to implement a better error reporting.
Packages installed!
Hello, if i use the Installscript the bot will be installed but after the start i get an error
How did you install the bot?
Sudo doesn't work.
@Qhiliqq erstmal großes Lob an deine Arbeit hier, scheinst echt aktiv drin zu stecken und den Leuten zu helfen.
Installieren tut er alles richtig keine Fehlermeldungen, habe trotzdem ein kleines Problem.
Habe im Wiki oder im Internet nichts zu der Meldung gefunden :
Installing Sinusbot update cronjob successful.
YouTube-DL already installed. Checking for updates.
Starting the Sinusbot. For first time.
Habe 4 mal versucht das ganze zu reinstallieren (auch mit Server-Restarts) und weiß nicht wo ich sonst ansetzen soll.
Wäre dankbar über jede Hilfe, das Problem muss ja irgendwie zu beheben sein (Wenn es geht ohne OS-Neuinstallation --> Meine Lösung für alles ^^)
PS: Habe Debian 8
@Qhilliqq hab das Installscript manuell über deinen Link runtergeladen und als root ausgeführt. Beim installieren kam eben der Error den @hendrick Koch auch hat, habe das Script dann nochmals ausgeführt aber statt Install habe ich Update gewählt und dann hats komischerweise funktioniert und der Bot lief. Also auch an dich @hendrick Koch probier nach dem Install nochmal das Update aus eventuell löst es ja auch dein Problem.
@Qhiliqq
brauche ein wenig Hilfe. Ich verstehe nicht wieso der Sinusbot nicht startet
Job for sinusbot.service failed. See 'systemctl status sinusbot.service' and 'journalctl -xn' for details.
root@debian:~# systemctl status sinusbot.service
Loaded: loaded (/lib/systemd/system/sinusbot.service; enabled)
Active: failed (Result: exit-code) since Sat 2017-04-29 19:33:41 EDT; 1min 54s ago
Process: 4623 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=217/USER)
Apr 29 19:33:41 debian systemd[1]: sinusbot.service: control process exited, code=exited status=217
Apr 29 19:33:41 debian systemd[1]: Failed to start Sinusbot, the Teamspeak 3 and Discord music bot..
Apr 29 19:33:41 debian systemd[1]: Unit sinusbot.service entered failed state.
Ich hab keine Ahnung, wieso es an dem User liegen sollte... habe den normalen user "sinusbot" genommen.
Operating System: / Linux
debian 8 64bit
i use this installer https://sinusbot-installer.de/
Failed install..
TS3 client install done.
Downloading latest Sinusbot.
Extracting Sinusbot files.
Sinusbot installation done.
Installed systemd file to start the Sinusbot with "service sinusbot {start|stop|status|restart}"
Config.ini created successfully.
Installing Cronjob for automatic Sinusbot update...
root@rpgonlyplayro:/home# service sinusbot status
   Active: failed (Result: exit-code) since Sun 2017-04-30 17:59:34 UTC; 4min 21s ago
Apr 30 17:59:34 rpgonlyplayro systemd[13822]: Failed at step USER spawning /bin/rm: No such process
Apr 30 17:59:34 rpgonlyplayro systemd[1]: sinusbot.service: control process exited, code=exited status=217
Apr 30 17:59:34 rpgonlyplayro systemd[1]: Failed to start Sinusbot, the Teamspeak 3 and Discord music bot..
Apr 30 17:59:34 rpgonlyplayro systemd[1]: Unit sinusbot.service entered failed state.
