Sinusbot Installer Script
Ich bekomme diese Nachricht wenn ich Sinusbot mit dien Link installieren möchte: root@28653b6d:~# bash <(wget --no-check-certificate -O - 'https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1530437519') converted 'https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1530437519' (ANSI_X3.4-1968) -> 'https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1530437519' (UTF-8) --2018-07-01 08:33:18-- https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1530437519 Resolving sinusbot-installer.de (sinusbot-installer.de)... 31.172.90.14 Connecting to sinusbot-installer.de (sinusbot-installer.de)|31.172.90.14|:443... connected. HTTP request sent, awaiting response... 403 Link expired, reload the site and try again 2018-07-01 08:33:18 ERROR 403: Link expired, reload the site and try again.
Weniger anzeigen
Bitte um Hilfe
ANTWORTEN
Weniger anzeigen
Bitte um Hilfe
ANTWORTEN
Bitte um LESEN ;)
Weiß nicht was daran unverständlich sein soll...
GUYS I NEED HELP
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 1098.
Which OS? Which virtualization? Need more informations guy....
Bin gerade während der Installation des Scriptes auf folgenden Error gestoßen:
2018/07/06 08:11:31 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2018/07/06 08:11:31 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2018/07/06 08:11:31 [GENERAL/RADIO ] INFO Could not find RadioStation-Data (or outdated), updating...
error starting up: listen tcp 0.0.0.0:8087: bind: address already in useCommand which failed was: " su -c "$LOCATION/sinusbot" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 1100.
OS: Debian 8.0 (64 Bit) basical
scheint als würde bereits etwas auf Port 8087 laufen
Ich bastel da mal noch was rein, dass wenn der Fehler kommt auch ne andere Error Meldung erscheint.
When you run `service sinus restart` I get this error:
Jul 10 23:11:18 server systemd[1]: sinusbot.service: Main process exited, code=exited, status=255/n/a
Jul 10 23:11:19 server systemd[1]: sinusbot.service: Unit entered failed state.
Jul 10 23:11:19 server systemd[1]: sinusbot.service: Failed with result 'exit-code'.
Anyway to fix it?
Anyway to fix it?
Hm no Idea...
You meant "service sinusbot restart"?
Command which failed was: "su -c "wget https://www.sinusbot.com/dl/sinusbot.curr ent.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the ou tput to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com /threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause t his is an error of your system not of the installer script. Line 812.
Guys pls help !!!
Both guys, which OS?
I never got those errors...
Hallo ich habe eine Probleme mit dem Sinusbot installer
also ich installiere ganz normal wie es auch mir an zeigt wirt
so bald alle gemacht Worte ist start er sich selber und ich logge mich ein alles gut
Failed to dump process list, ignoring: Input/output error
Active: active (running) since Sat 2018-07-21 11:57:10 CEST; 4min 26s ago
Process: 1022 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
Main PID: 1070 (sinusbot)
CGroup: /system.slice/virtualizor.service/system.slice/sinusbot.service
aber dann wenn ich ein Skript ein füge. dann muss ich den sini.bot ja restart oder stop
dann mache ich status
Active: inactive (dead) since Sat 2018-07-21 12:03:02 CEST; 12s ago
Process: 1732 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
Process: 1070 ExecStart=/opt/sinusbot/sinusbot (code=killed, signal=INT)
Main PID: 1070 (code=killed, signal=INT)
aber er stop nicht sonder er lauft weiter weiter
hmm okay ich starte in noch mal
dann mache ich Status und dann das
Active: failed (Result: exit-code) since Sat 2018-07-21 12:04:01 CEST; 1s ago
Process: 1853 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
Process: 1830 ExecStart=/opt/sinusbot/sinusbot (code=exited, status=255)
Process: 1827 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
Main PID: 1830 (code=exited, status=255)
aber wenn ich sini.bot alles Lösche ist er auch off
Kann mir jemand helfen ??
Hier kann evtl. @Xuxe helfen :)
