Update is in work, it will be done today or tomorrow
Could not detect latest TS3-Client version
Naja geistig und warscheinlich körperlich unterlegen. Sowas denke ich, brauchen wir hier nicht.
.Exakt... wobei das auch nicht gerade von geistiger Reife zeugt.
Ich würde sagen jetzt beruhigen sich mal alle beteiligten es geht hier ja schließlich nur um einen Bot.
Command which failed was: "su -c "wget https://www.sinusbot.com/dl/sinusbot.current.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread.
Auf OVH hatte ich noch nie Probleme.Hay,
Ich habe zurzeit auf mein OVH vServer das Problem beim Install Script
Ist aber wenigsten schön das die Teamspeak Version wieder gefunden wird ^^
Mit freundlichen Grüßen
Johannes K. | MrUnknwonDE
On the installer page stands CentOS 6 or higher, but I think the Overview page here is more up to date. So am I right that you get an error if you try to use the installer script normally? If it doesn't work normally I think you have to upgrade to CentOS 7. Wouldn't that be possible?Hello, i have an error when downloading SinusBot with script, I run it on Linux CentOs 6.2 VPS.
I think CentOS 6.2 does not support sinusbot installer script but is there another way to install?
I installed Glibc 2.14 on my VPS but i still get this error:
./sinusbot: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by ./sinusbot)
Failed to read password, try a reinstall again. sinusbot
I think you should upgrade your teamspeak because otherwise users who updatet their client to the newest version (which are most of the users) also can't join. ^^Now I installed Debian 8 minimal and I have new problem, my TS3 server is on older version (i can not update it) but new sinusbot does not support old version, how to download older version of sinusbot installer script?
