Sinusbot Installer Script
login as: sinusbot
[email protected]'s password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
sinusbot@vps:~$ RunningAsRootIsEvilAndIKnowThat
-bash: RunningAsRootIsEvilAndIKnowThat: command not found
sinusbot@vps:~$ ./sinusbot -pwreset=foobar
-bash: ./sinusbot: No such file or directory
sinusbot@vps:~$ cd /opt/sinusbot
sinusbot@vps:/opt/sinusbot$ ./sinusbot -pwreset=foobar
Version: 0.9.12.3-5b7c0cd
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChanne l.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2016/07/23 08:09:27 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2016/07/23 08:09:27 X [MAIN] Starting up fake x-server...
2016/07/23 08:09:27 Could not open X11 socket. This happens either if the bot is already running or you ran it before using a different user (root?). Please mak e sure the bot is not running and delete /tmp/.X11-unix/X40 manually.
sinusbot@vps:/opt/sinusbot$ ^C
sinusbot@vps:/opt/sinusbot$ cd
sinusbot@vps:~$ wget https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd.tar. bz2
converted 'https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd.tar.bz2' (ANSI _X3.4-1968) -> 'https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd.tar.bz2' (UTF-8)
--2016-07-23 08:10:03-- https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd. tar.bz2
Resolving www.sinusbot.com (www.sinusbot.com)... 104.18.41.220, 104.18.40.220
Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.41.220|:443... connecte d.
Length: 13543015 (13M) [application/octet-stream]
Saving to: 'sinusbot-0.9.12.3-5b7c0cd.tar.bz2'
sinusbot-0.9.12.3-5 100%[=====================>] 12.92M 74.5MB/s in 0.2s
2016-07-23 08:10:04 (74.5 MB/s) - 'sinusbot-0.9.12.3-5b7c0cd.tar.bz2' saved [135 43015/13543015]
sinusbot@vps:~$ tar -xjvf sinusbot-0.9.12.3-5b7c0cd.tar.bz2
config.ini.dist
README.md
sinusbot
libavcodec.so.57
libavformat.so.57
libavutil.so.55
libswresample.so.2
libavfilter.so.6
scripts/advertising.js
scripts/aloneMode.js
scripts/badchan.js
scripts/bookmark.js
scripts/covatar.js
scripts/dev.js
scripts/followme.js
scripts/idle.js
scripts/metadata.js
scripts/norecording.js
scripts/rememberChannel.js
scripts/showcase.js
scripts/sound.js
scripts/welcometext.js
plugin/libsoundbot_plugin.so
sinusbot@vps:~$ cp plugin/libsoundbot_plugin.so TeamSpeak3-Client-linux_amd64/pl ugins/
cp: cannot create regular file 'TeamSpeak3-Client-linux_amd64/plugins/': No such file or directory
sinusbot@vps:~$ ^C
sinusbot@vps:~$ su root
Password:
root@vps:/home/sinusbot# cp plugin/libsoundbot_plugin.so TeamSpeak3-Client-linux _amd64/plugins/
root@vps:/home/sinusbot# ./sinusbot -pwreset=
2016/07/23 08:11:00 The bot will not run as root-user if you don't run it with t he parameter '-RunningAsRootIsEvilAndIKnowThat'
root@vps:/home/sinusbot# su sinusbot nusbot# ./sinusbot -pwreset=
su: invalid option -- 'w'
Usage: su [options] [LOGIN]
Options:
-c, --command COMMAND pass COMMAND to the invoked shell
-h, --help display this help message and exit
-, -l, --login make the shell a login shell
-m, -p,
--preserve-environment do not reset environment variables, and
keep the same shell
-s, --shell SHELL use SHELL instead of the default in passwd
root@vps:/home/sinusbot# cp plugin/libsoundbot_plugin.so teamspeak3-client/plugi ns/
cp: cannot create regular file 'teamspeak3-client/plugins/': No such file or dir ectory
root@vps:/home/sinusbot# ^C
root@vps:/home/sinusbot# ls
README.md libavformat.so.57 scripts
config.ini.dist libavutil.so.55 sinusbot
libavcodec.so.57 libswresample.so.2 sinusbot-0.9.12.3-5b7c0cd.tar.bz2
libavfilter.so.6 plugin
root@vps:/home/sinusbot# cd
root@vps:~# root@vps:/home/sinusbot# cp plugin/libsoundbot_plugin.so teamspeak3- client/plugins/
bash: root@vps:/home/sinusbot#: No such file or directory
root@vps:~# cp: cannot create regular file 'teamspeak3-client/plugins/': No such file or directory
bash: cp:: command not found
root@vps:~# su sinusbot root@vps:/home/sinusbot# cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins/
bash: root@vps:/home/sinusbot#: Permission denied
root@vps:~# sinusbot
bash: sinusbot: command not found
sinusbot@vps:/root$ root@vps:/home/sinusbot# cp plugin/libsoundbot_plugin.so tea mspeak3-client/plugins/
sinusbot@vps:/root$ cp: cannot create regular file 'teamspeak3-client/plugins/': No such file or directory
sinusbot@vps:/root$ cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins/
cp: failed to access 'teamspeak3-client/plugins/': Permission denied
sinusbot@vps:/root$ ^C
sinusbot@vps:/root$ so root
bash: so: command not found
sinusbot@vps:/root$ su root
Password:
su: Authentication failure
Password:
root@vps:~# wget https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd.tar.bz2
--2016-07-23 08:15:44-- https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd. tar.bz2
Resolving www.sinusbot.com (www.sinusbot.com)... 104.18.40.220, 104.18.41.220
Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.40.220|:443... connecte d.
sinusbot-0.9.12.3-5 100%[=====================>] 12.92M 66.6MB/s in 0.2s
2016-07-23 08:15:45 (66.6 MB/s) - 'sinusbot-0.9.12.3-5b7c0cd.tar.bz2' saved [135 43015/13543015]
root@vps:~# tar -xjvf sinusbot-0.9.12.3-5b7c0cd.tar.bz2
config.ini.dist
README.md
sinusbot
libavcodec.so.57
libavformat.so.57
libavutil.so.55
libswresample.so.2
libavfilter.so.6
scripts/badchan.js
scripts/bookmark.js
scripts/covatar.js
scripts/dev.js
scripts/followme.js
scripts/idle.js
scripts/metadata.js
scripts/showcase.js
scripts/sound.js
root@vps:~# cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins/
root@vps:~# cd /opt/sinsubot
bash: cd: /opt/sinsubot: No such file or directory
root@vps:~# cd /opt/sinusbot
root@vps:/opt/sinusbot# cp plugin/libsoundbot_plugin.so teamspeak3-client/plugin s/
root@vps:/opt/sinusbot# ./sinusbot -pwreset=foobar
2016/07/23 08:16:43 The bot will not run as root-user if you don't run it with t he parameter '-RunningAsRootIsEvilAndIKnowThat'
root@vps:/opt/sinusbot# su ./sinusbot -pwreset=
Options:
-m, -p,
keep the same shell
sry für spamm das ist was die consoel sagt
du musst auch schon im Sinusbot Installationsordner Sein :eek::eek::eek:
When you gonna update this? Not working on my debian 8
It says "Error: Could not detect OS. Currently only Debian, Ubuntu and CentOS are supported. Aborting!"
ok try this before you start the installer script "apt-get update && apt-get upgrade && apt-get dist-upgrade"
Habe soeben den Bot per Skript auf meinen root (Debian 8 64-Bit) installiert. Keine Fehler. Will dann auf das Webinterface und mich mit den, in der Konsole stehenden Informationen, einloggen. Aber das Webinterface sagt: "Unauthorized" - Habe auch mal copy'n Paste gemacht aber ging trotzdem nicht.
Oh... - Ich habe bereits 3mal SinusBot installiert und das 2. mal mit diesem Skript hier. Ich wusste nicht, dass es mittlerweile ein zufälliges ist. In diesem Fall bitte ein Update, dass da nicht foobar als Password angegeben wird (vom Skript)
### German ###
Achtung! Installer aktuell nicht nutzbar, da neue Sinusbot Version!
Update im laufe des Wochenendes!
### English ###
Attention! Installer is unusable at the moment, because of the new sinusbot version!
Update during the weekend!
Work in progress...
./sinusbot -pwreset=DeinPasswort
Geht nicht ....
Komme ins Interface nicht rein ..
so (: da man anscheinend kein FAQ lesen kann.
du stopst erstmal den Bot mit
/etc/init.d/sinusbot stop
danach führst du folgendes in deinem ssh terminal aus
./sinusbot -pwreset=deinpasswort
dann sobald der bot gestartet ist,
stopst du ihn mit STRG-C
und dann startest du ihn normal mit
folgenden befehl
/etc/init.d/sinusbot start
