Sinusbot Installer Script
Qhiliqq aktualisierte Sinusbot Installer Script mit einem neuen Eintrag:
Password Fixed
### German ###
Neue Version verfügbar.
Changelog:
  • Passwort Problem behoben
Bei Fehlern und Problemen bitte erst in dem Reiter Diskussion das Problem schildern und nicht gleich eine schlechte Bewertung geben, denn so kann ich euch nicht helfen.
### English ###
New version available.
Changelog:
  • Password problem fixed
If you have bugs or problems use first the discuss tab and write down the problem, before you write a bad evaluation. This doesn't help...
Weitere Informationen zur Aktualisierung...
Doesn't seem like the password fix did anything? Still gave me the default admin and foobar, when I try and use those it says unauthorized.
Problem when i start the bot :
2016-07-26T20:21:34+02:00 Storing configuration.
2016-07-26T20:21:28+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2016-07-26T20:21:28+02:00 Closed.
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so)
2016-07-26T20:21:28+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64)
2016-07-26T20:21:28+02:00 Starting instance ts3server://ts.stownsharks.fr?port=9987&nickname=%5BBOT%5D%20NCS%20Dubstep%20%2F%20Electro&password=&channel=&channelpassword=
Which Version is shown when you start the bot?
More informations please! Which OS and so on.
I'm on Debian 7 :
vCPU2 RAM4 Go SSD32 Go
I install SinusBot with the latest version of your installer ( 1.2.6 [PASSWORD FIXED] )
When i press the buttons "Start" for connecting the bot,
it's do nothing and i have these error in the instances logs
Sorry for bad english x)
I'm on Debian 7 :
apt-get install libglib2.0-0
Reading package lists... Done
Building dependency tree
libglib2.0-0 is already the newest version.
that's change nothing :c
Then edit the sources.list under /etc/apt/sources.list and add:
deb http://httpredir.debian.org/debian  sid main contrib non-free
deb-src http://httpredir.debian.org/debian sid main contrib non-free
After that:
apt-get update
apt-get install -t sid libc6
This should work :)
I just installed the bot using the script and have the following comments:
1) I had youtube-dl installed (manually via the following)
sudo wget https://yt-dl.org/downloads/latest/youtube-dl -O /usr/local/bin/youtube-dl
sudo chmod a+rx /usr/local/bin/youtube-dl
And the install script said it found it, but didn't update the path in the config.ini so I had to manually adjust that
2) The random password DID work for me so yay, good job :)
3) The bot launched at the end of the script and it works! Yay!
4) I'm having issues starting the bot from the init.d script. I tried starting it from my user, root, and then the sinusbot user and I get the following message:
sinusbot@play:/root$ /etc/init.d/sinusbot start
Using following data:
USER: sinusbot
DIR ROOT: /opt/sinusbot/
BOT RUN CMD: ./sinusbot
Starting sinusbot...
You are not the owner of /var/run/screen/S-sinusbot.
sinusbot started successfully
sinusbot@play:/root$ /etc/init.d/sinusbot status
sinusbot is DOWN
sinusbot@play:/root$ cd ~
sinusbot@play:~$ /etc/init.d/sinusbot start
USER: sinusbot
sinusbot@play:~$ /etc/init.d/sinusbot status
sinusbot is DOWN
Running Debian 8 and latest updates and patches
Any ideas?
Thanks,
Also great work on this script. It GREATLY simplified my frustration and install. 5 stars
Ups, fixing that soon.
Good :cool:
Very good :D
USER: sinusbot
sinusbot is DOWN
USER: sinusbot
sinusbot is DOWN
The startup script is from @Xuxe.
But normally this should work... hmm...:confused:
I figured it out :) This was a relic from back when I was trying to get it working manually, so I had to switch to root and chown -R sinusbot:sinusbot /var/run/screen/S-sinusbot
Works now - thank you!
After that:
apt-get update
This should work :)
When i execute the command apt-get install
i have this error at the end of the install :
W: Ignoring Provides line with DepCompareOp for package dh-systemd
W: Ignoring Provides line with DepCompareOp for package libjpeg62
W: Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
W: Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
W: Ignoring Provides line with DepCompareOp for package php-seclib
W: Ignoring Provides line with DepCompareOp for package php-sabre-http
W: Ignoring Provides line with DepCompareOp for package php-math-biginteger
W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
W: You may want to run apt-get update to correct these problems
Read yourself^^
Already do that...
APT GET UPDATE =
thank you for this very fast eScript very useful and successful login the web interface ... so the one thing I am having poblema with the scripts they do not saved and can not trigger any help me people .... thanks
Danke für den schnellen Fix was das PW betrifft :)
Auch das während der Installation bzw. am Ende das zufällig generierte PW angezeigt wird.
Installation läuft sauber durch und es läuft am Ende alles wie es soll.
Habe auf meiner Test Installation unter Debian 7 es auch probiert. Und selbst dort läuft alles. Nur wenn man den Bot startet schließt er sich
sofort wieder. Aber das Problem das er mit dem aktuellen Teamspeak Client unter Deb7 nicht läuft ist ja bekannt und kann wie gewohnt mit dem Einspielen der Version 3.0.18.2 behoben werden. Auch getestet und läuft
Aber ich habe mittlerweile auf Deb 8 umgestellt und läuft :)
Danke für das klasse Script.
best regards mcburn
thanks again ,, could fix the error by clome google could not configure the scripts and save ,, but the smartphone could configure all escripts forces
desculpe pelo meu Inglês ,,,, eu estava erros em scripts scripts não salvos pelo Google clome mas eu salvo para o meu telefone celular por isso obrigado ...
