What do you mean by this? I'm having the same issue as @clack. I ran this command in root and restarted the bot but I still can't connect to TS (using the correct IP and port). Is there somewhere specific I should install this TS? If so, how do I do it?Just download this TeamSpeak version
wget http://dl.4players.de/ts/releases/3.0.18.2/TeamSpeak3-Client-linux_amd64-3.0.18.2.run
2016-07-15T00:33:25-04:00 TSClient quit.
2016-07-15T00:33:25-04:00 Starting instance ts3server://192.99.21.112?port=9987&nickname=SignaturedBot&password=&channel=&channelpassword=
2016-07-15T01:59:06-04:00 TSClient quit.
2016-07-15T01:59:06-04:00 EOF
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so)
2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64)
2016-07-15T01:59:06-04:00 Starting instance ts3server://ts.brawl.com?port=9987&nickname=SigBot&password=&channel=&channelpassword=
Your System is too old. Update to Debian 8 or update GlibC (libc6) yourself. But that is very very risky, because that library is really important and needed for everything, so you can destroy your system easily.What do you mean by this? I'm having the same issue as @clack. I ran this command in root and restarted the bot but I still can't connect to TS (using the correct IP and port). Is there somewhere specific I should install this TS? If so, how do I do it?
Operating System: Debian 7 (Wheezy) (64-bit version)
Code:2016-07-15T00:33:25-04:00 TSClient quit. 2016-07-15T00:33:25-04:00 Starting instance ts3server://192.99.21.112?port=9987&nickname=SignaturedBot&password=&channel=&channelpassword=
EDIT:
This is what happens when I set LogLevel to 10
Code:2016-07-15T01:59:06-04:00 TSClient quit. 2016-07-15T01:59:06-04:00 EOF 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++abi.so.1) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libc++.so.1) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Sql.so.5) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Widgets.so.5) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Network.so.5) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Gui.so.5) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libQt5Core.so.5) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/libquazip.so) 2016-07-15T01:59:06-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.14' not found (required by /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64) 2016-07-15T01:59:06-04:00 Starting instance ts3server://ts.brawl.com?port=9987&nickname=SigBot&password=&channel=&channelpassword=
Starting sinusbot...
You are not the owner of /var/run/screen/S-sinusbot.
sinusbot started successfully
Please wait... This will take 15 seconds!
Sinusbot could not start! Starting it without screen. Look for errors! Stop it again in 10 seconds.
sinusbot: no process found
rm: cannot remove `./sinusbot_installer.sh': No such file or directory
- Operating System: Debian GNU/Linux 7.11 (wheezy)
- Kernel: Linux 3.2.0-4-amd64 x86_64
- Load Average: 1.06 1.09 1.12
- Uptime: 82 days, 20 hours, 36 minutes, 2 seconds
- OS APT Last Update: 21.07.2016 19:09:08 CEST +02:00:00
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
CPU MHz: 2099.998
Hypervisor vendor: KVM
Virtualization type: full
- RAM: B/13.73 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 3.74 GB/930.55 GB in use (0%)
> libglib: 2.33.12+really2.32.4-5
- Binary: /opt/sinusbot/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
- Version: 0.9.12-58b509d
- TS3 Plugin: unknown (TS3client not found)
- Bot Plugin: unknown
- TS3 Client: unknown
- TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (TS3client-binary does not exist!)
- YoutubeDLPath = not set (does exist anyway, version: 2016.07.17)
- Report date: 21.07.2016 19:47:32 CEST +02:00:00 (timezone: Europe/Berlin)
- TeamSpeak 3 Version: unknown
- youtube-dl Version: 2016.07.17
- DiagScript version: 0.4.5
Verwende diese Version:Moinsen,
ich habe auch ein Problem mit dem Installer. Seit mehr als 4 Stunden sitz ich hier und versuche den Bot zum laufen zu kriegen.
Ich habe es nach Anleitung installiert jedoch startet er den Bot nicht (aus welchem Grund auch immer)
Code:Starting sinusbot... You are not the owner of /var/run/screen/S-sinusbot. sinusbot started successfully Please wait... This will take 15 seconds! Sinusbot could not start! Starting it without screen. Look for errors! Stop it again in 10 seconds. sinusbot: no process found rm: cannot remove `./sinusbot_installer.sh': No such file or directory
Code:========================================================== SINUSBOT RELATED SYSTEM INFORMATION - Operating System: Debian GNU/Linux 7.11 (wheezy) - OS x64 check: OK - Kernel: Linux 3.2.0-4-amd64 x86_64 - Load Average: 1.06 1.09 1.12 - Uptime: 82 days, 20 hours, 36 minutes, 2 seconds - OS Updates: 0 (well done!) - OS Missing Packages: None (v1) - OS APT Last Update: 21.07.2016 19:09:08 CEST +02:00:00 - Bot Start Script: found at /etc/init.d/sinusbot [perms: 755] - DNS resolution check: google.com -> OK - CPU: Architecture: x86_64 CPU(s): 4 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 CPU MHz: 2099.998 Hypervisor vendor: KVM Virtualization type: full - RAM: B/13.73 GB in use (%) - SWAP: B/ B in use (%) - DISK: 3.74 GB/930.55 GB in use (0%) - Package versions: > libglib: 2.33.12+really2.32.4-5 BOT INFORMATION - Status: not running - Webinterface: port locally reachable (Port: 8087) - Binary: /opt/sinusbot/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d) - Version: 0.9.12-58b509d - TS3 Plugin: unknown (TS3client not found) - Bot Plugin: unknown - TS3 Client: unknown - Config: - LogLevel = 10 (debug log active) - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (TS3client-binary does not exist!) - YoutubeDLPath = not set (does exist anyway, version: 2016.07.17) - Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; norecording.js; rememberChannel.js; showcase.js; sound.js; welcometext.js OTHER INFORMATION - Report date: 21.07.2016 19:47:32 CEST +02:00:00 (timezone: Europe/Berlin) - TeamSpeak 3 Version: unknown - youtube-dl Version: 2016.07.17 - DiagScript version: 0.4.5 ==========================================================
Ich bin leider mit meinem Latein am Ende. Vielleicht habt ihr eine Idee. Vielleicht habe ich auch einfach nur was übersehen....
Danke im voraus!
Sauber! Hat geklappt!Verwende diese Version:
https://www.sinusbot.com/pre/sinusbot-0.9.12-26f5d66.tar.bz2
Welche du aber manuell in /opt/sinusbot entpacken müsstest und das Plugin kopieren müsstest.
Perfekt. Wieder was dazu gelernt.Er generiert ab dieser Version ein zufälliges Passwort. Am einfachsten ist es den Bot, miteins zuzuweisenCode:./sinusbot -pwreset=DeinPasswort
Ist diese jetzt neuer als die Version 0.9.12.2-58b509d ?Verwende diese Version:
jaIst diese jetzt neuer als die Version 0.9.12.2-58b509d ?
habe das selbe wie mcburn consoel sagt mir das
root@vps:~# ./sinusbot -pwreset=foobar
-bash: ./sinusbot: No such file or directory
root@vps:~#
wget https://www.sinusbot.com/pre/sinusbot-0.9.12.3-5b7c0cd.tar.bz2
tar -xjvf sinusbot-0.9.12.3-5b7c0cd.tar.bz2
cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins/
cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins/sinusbot@vps:~$ cp plugin/libsoundbot_plugin.so TeamSpeak3-Client-linux_amd64/plugins/
cp: cannot create regular file 'TeamSpeak3-Client-linux_amd64/plugins/': No such file or directory
sinusbot@vps:~$
