Sinusbot Installer Script
Hey there,
Ich kann das Script leider nicht herunterladen.
Sobald ich das Script herunterladen möchte, kommt in einer Fehler in der Konsole:
GnuTLS: A TLS fatal alert has been received.
Unable to establish SSL connection.
Im Internet finde ich leider nur die Info, dass SSLv2 nicht verwendet bzw. explizit ausgeschlossen wird. Damit kann ich jedoch nichts anfassen.
\\:EDIT: Habe mir den Installer nun über GITHUB heruntergeladen. Damit gings
./TeamSpeak3-Client-linux_amd64-3.0.19.4.run: line 578: cd: TeamSpeak3-Client-linux_amd64: Not a directory
cp: cannot stat ‘./TeamSpeak3-Client-linux_amd64/*’: No such file or directory
Error on line 744. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L744
Hi guys,
I really don't know what to do with my server. After a try of updating sinusbot on my server I got an error and I can't install it back :/ Error apears after a message ''Starting systemd installation''. Please help :)
Error:
Error on line 823. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L823
Could there be a version which does not need ROOT PERMS?
Nope.
I have a problem with scrypt. I install on clear Debian 8.
Username [sinusbot]:
Your sinusbot user is: sinusbot
User "sinusbot" already exists.
Downloading TS3 client files.
Installing the TS3 client.
Read the eula!
Do the following: Press "ENTER" then press "q" after that press "y" and accept it with another "ENTER".
Welcome to the TeamSpeak 3 Client for Linux on amd64 installer
In order to install this software you are required to accept the license
agreement, please press return to view the license.
You can scroll with the arrow keys and quit the viewer by pressing 'q'.
[RETURN]
q
Please type y to accept, n otherwise: y
Uncompressing TeamSpeak 3 Client for Linux on amd64 100%
TS3 client install done.
Downloading latest SinusBot.
Error while downloading with cURL (Status = 403). Trying it with wget.
Error on line 768. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L768
root@Sinusbot:/opt/ts3soundboard#
EDIT: https://scr.hu/9yKMRa
Ehm, your server can't connect to sinusbot.com for downloading the files.
Hey there,
Hm komisch, den Fehler hatten wir noch nie.
Genau über Git sollte es dann spätestens gehen.
Reinstall the sinusbot.
Hi guys,
Error:
Hello.
I am not really sure why your script does not work on Ubuntu 17.04 LTS. I run the script as shown on your website and it gets stuck when it searches for updates. You can't choose option 3, which is total nonsense as in you ask in your script if the script needs to search for updates and if you don't want to let it check for updates it exits, and it constantly crashes when it installs the required dependencies. Is there a way to solve this issue? http://prntscr.com/g7wzwm
Ist bei dem Installer schon ein Eintrag als Autostart vorhanden oder muss man den nach der Installation noch selbst anlegen?
Der Pfad zu der Datei welche dann ausgeführt wird, heißt /lib/systemd/system/sinusbot.service
Der Sinusbot selbst wird in das Verzeichnis /opt/sinusbot/ Standardmäßig installiert
Moin, bist Du Dir da sicher? Ich habe die von Dir angegebene Datei nicht auf meinem Linux-Server in der README_installer steht was, das der autostart-Prozess woll eher in die Datei /etc/init.d zu gehören scheint....
So jetzt werde ich das mal prüfen, ob da ein Eintrag vorhanden ist ansonsten werde ich den dort einfügen...
edit: habe das jetzt hinbekommen, bzw. es war ja schon eine Autostart vorhanden. Nun habe ich noch eine für TS3 eingefügt und alles ist tutti paletti
Error while downloading youtube-dl with cURL. Trying it with wget.
Error on line 918. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L918
First of all, delete your sinusbot with the installer.
Then try a manual YT-DL Installation:
Try
wget -q -O /usr/local/bin/youtube-dl http://yt-dl.org/downloads/latest/youtube-dl
manually and after this
chmod a+rx /usr/local/bin/youtube-dl
youtube-dl -U --restrict-filename
Install your sinusbot again, without YT-DL and edit the "YoutubeDLPath" in /opt/sinusbot/config.ini to "YoutubeDLPath = /usr/local/bin/youtube-dl"
Extracting SinusBot files.
SinusBot update done.
(reinstalling dosnt work)
Start your bot manually and send the output here.
su sinusbot
/opt/sinusbot/sinusbot
ich habe derzeit Probleme mit dem Sinusbot-Installer...
wenn ich ihn durchlaufen lasse, dann kommt dieser Fehler
ich kriege keine Verbindung hin.... heute nachmittag hat es noch funktioniert.
