root@ns508009:~# bash <(wget --no-check-certificate -O - 'https://sinusbot-installer.de/download.php?s=5829b25b7d817ad6e9b42d8dd0f6aa4b&t=1500462482')
--2017-07-19 00:12:06-- https://sinusbot-installer.de/download.php?s=5829b25b7d817ad6e9b42d8dd0f6aa4b&t=1500462482
Length: 31717 (31K) [application/octet-stream]
Saving to: ‘STDOUT’
- 100%[=====================================================================================>] 30.97K --.-KB/s in 0.001s
2017-07-19 00:12:06 (30.7 MB/s) - written to stdout [31717/31717]
Your installer is up-to-date.
You're using Installer 1.3.10
What should the Installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
1) Automatic
2) Own path
3) Quit
1) Automatic
2) Own path
3) Quit
#? 2
Enter location where the bot should be installed/updated/removed. Like /opt/sinusbot. Include the / at first position and none at the end!
Location [/opt/sinusbot]: /home/sinusbot2
Your directory is /home/sinusbot2.
1) Yes
2) No, change it
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
1) Yes
2) Try without
3) No
#? 1
Start installer now!
Packages installed!
Please enter the name of the sinusbot user. Typically "sinusbot". If it does not exists, the installer will create it.
Username [sinusbot]:
Your sinusbot user is: sinusbot
Downloading TS3 client files.
Installing the TS3 client.
Read the eula!
Do the following: Press "ENTER" then press "q" after that press "y" and accept it with another "ENTER".
Welcome to the TeamSpeak 3 Client for Linux on amd64 installer
In order to install this software you are required to accept the license
agreement, please press return to view the license.
You can scroll with the arrow keys and quit the viewer by pressing 'q'.
[RETURN]
Please type y to accept, n otherwise:
Please type y to accept, n otherwise: y
Uncompressing TeamSpeak 3 Client for Linux on amd64 100%
TS3 client install done.
Downloading latest SinusBot.
Extracting SinusBot files.
SinusBot installation done.
Starting init.d installation
Installed init.d file to start the SinusBot with "/etc/init.d/sinusbot {start|stop|status|restart|console|update|backup}"
config.ini created successfully.
Installing Cronjob for automatic SinusBot update...
Installing SinusBot update cronjob successful.
Installing YT-Downloader now!
Cronjob already set for YT-DL updater!
Downloading YT-DL now...
Download successful!
youtube-dl is up-to-date (2017.07.15)
Can't set your date automatically. Please follow the following steps:
Day (01-32): 19
Month (01-12): 07
Year (2017): 2017
Choose your time format:
1) 12 hour
2) 24 hour
#? 2
Hour (1-24): 13
Minute (0-59): 1
Second (0-59): 0
13:01:00
20170719
Deleted /tmp/.sinusbot.lock
Starting the SinusBot. For first time.
2017/07/19 00:00:00 X [MAIN] Starting up fake x-server...
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2017/07/19 00:00:00 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2017/07/19 00:00:03 Updating database to v1... 0
2017/07/19 00:00:03 Updating database to v2... 1
2017/07/19 00:00:03 Updating database to v3... 2
2017/07/19 00:00:03 Updating database to v4... 3
2017/07/19 00:00:03 Updating database to v5... 4
2017/07/19 00:00:04 Updating database to v6... 5
2017/07/19 00:00:04 Updating database to v7... 6
2017/07/19 00:00:04 780acada INFO Loading instances
2017/07/19 00:00:04 780acada INFO Creating default instance
2017/07/19 00:00:04 780acada 91286fcd INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017/07/19 00:00:04 X [MAIN] New connection
2017/07/19 00:00:04 780acada INFO Promoting instance to main instance
2017/07/19 00:00:04 780acada INFO Adding new user admin
Starting SinusBot again. Your admin password = 'PMK0ipvw'
Using following data:
USER: sinusbot
DIR ROOT: /home/sinusbot2/
BOT RUN CMD: ./sinusbot
Starting sinusbot...
No directory, logging in with HOME=/
You are not the owner of /var/run/screen/S-sinusbot.
sinusbot started successfully
Please wait... This will take some seconds!
Version: 0.9.21-87a90ce
2017/07/19 00:00:18 X [MAIN] Starting up fake x-server...
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2017/07/19 00:00:19 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
a manual update is required
Error on line 1035. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L1035
root@ns508009:~#
