Sinusbot Installer Script
Can you try just 'apt-get update' and see if you receive the same error?
Note that this command may take a long time as well.
Ok I fixed this error in the meantime, but I got a new one when I run the script:
/dev/fd/63: line 688: update-ca-certificates: command not found
I thought about installing it, but there is no package named equally
apt-get install -y update-ca-certificates
If you have not done yet on your VPS run the 'apt-get update'
Then run 'apt-get install -y ca-certificates'
Then run the 'update-ca-certificates'
See if this works or not.
Regards.
Regards.
Hey, yes I have done the update, no errors.
ca-certificates was installed, checked it:
Reading package lists... Done
Building dependency tree
ca-certificates is already the newest version (20170717~17.04.1).
I tried the script again, but the Error remained:
Error on line 688. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " update-ca-certificates >/dev/null". Please try to execute it manually and attach the output to the bug report in the forum thread.
Greetings
Okay until he comes back on (As he probably knows exactly what is wrong) we can try a few other things.
Try:
sudo apt-get install --reinstall ca-certificates
Then re-try.
If it doesn't work you can try purging them:
sudo dpkg --purge --force-depends ca-certificates
sudo apt-get -f install
Let me know how these go.
Try:
Then re-try.
Hmm no change in the script output, the error remains after both hotfixes:confused:
Did you try re-run the:
then
Try this command:
apt-get -qq install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 curl less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 -y >/dev/null
See if you still get errors from that and when you try to install the bot again, I am guessing it will be the same as before.
then
Try this command:
Thanks for your Help
Unfortunately, update-ca-certificate is still an unknown command
with an "s"
I think he just missed the 's' when replying, as I did put the 's' on my command.
@Ironeer
Currently just setting up TeamSpeak on a new test server (as my other one doesn't seem to let me select Ubuntu 17.04.... :/ ) to see if I can replicate the errors, please bear with me.
I did do the apt-get update and all that and have received no errors so far though.
with an "s"
I only missed the 's' in the post, I copied everything to the console
root@vmd12916:~# update-ca-certificates
bash: update-ca-certificates: command not found
root@vmd12916:~# apt-get install -y update-ca-certificates
E: Unable to locate package update-ca-certificates
@Ironeer
'apt-get install -y ca-certificates' not 'apt-get install -y update-ca-certificates'
Also, just installed onto test server and everything went without a hitch using Ubuntu 17.04.
Re-try with corrected above code. If this still does not work we could try a last resort thing, but, this is up to you.
We would be re-imaging the VPS and doing a fresh install.
Unless @Qhiliqq has another suggestion/fix?
Regards.
@Ironeer
Regards.
I tried another time, but I did install ca-certificates before.
Nevertheless here again my code:
root@vmd12916:~# apt-get install -y ca-certificates
root@vmd12916:~# bash <(wget --no-check-certificate -O - 'https://sinusbot-installer.de/download.php?s=fbbdc53afd341c3f5cd84779cef1a819&t=1514293428')
--2017-12-26 13:53:54-- https://sinusbot-installer.de/download.php?s=fbbdc53afd341c3f5cd84779cef1a819&t=1514293428
Length: 34270 (33K) [application/octet-stream]
Saving to: 'STDOUT'
- 100%[===================>] 33.47K --.-KB/s in 0s
2017-12-26 13:53:54 (326 MB/s) - written to stdout [34270/34270]
Your installer is up-to-date.
You're using Installer 1.4
What should the Installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
/dev/fd/63: line 272: virt-what: command not found
/dev/fd/63: line 274: virt-what: command not found
1) Automatic
2) Own path
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
/dev/fd/63: line 542: virt-what: command not found
Check your time below:
DATE: 12/26/17
TIME: 13:54:08
1) Correct
2) Incorrect
#? 1
1) Yes
2) Try without
3) No
#? 1
Start installer now!
Detected latest TS3-Client version as 3.1.7
root@vmd12916:~#
I'm not willing to re-image, then I think I have to live without a sinusbot if nobody knows the issue :/
Thanks for your help, maybe anyone has another idea
I understand, especially when you have alot of invaluable stuff on the VPS, though I do re-call you saying it was a 'fresh install'?
Anyway, let's try the following first:
sudo apt-get remove ca-certificates
then
sudo apt-get purge ca-certificates
(This will remove and then purge the certificates)
Then again:
apt-get install ca-certificates
then
Let's see how this goes.
Regards
then
Then again:
then
Regards
Yeah, you're right is was a fresh install, but in the meantime I set two gameserver and one of my own java servers up..:rolleyes:
After the removal and purge the installation generates an error output:
root@vmd12916:~# apt-get install ca-certificates
The following packages were automatically installed and are no longer required:
apg apturl-common avahi-utils bubblewrap cups-pk-helper five-or-more flatpak
fonts-dejavu-extra four-in-a-row gir1.2-grilo-0.3 gir1.2-gspell-1
gir1.2-mediaart-2.0 gnome-chess gnome-clocks gnome-control-center-data
gnome-dictionary gnome-games gnome-klotski gnome-nibbles gnome-robots
gnome-software-common gnome-sound-recorder gnome-taquin gnome-tetravex
hitori hoichess iagno ippusbxd java-common libatk-wrapper-java
libatk-wrapper-java-jni libcaribou-gtk-module libcaribou-gtk3-module
libfile-listing-perl libflatpak0 libfont-afm-perl libgdict-1.0-10
libgdict-common libgsound0 libhtml-form-perl libhtml-format-perl
libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl
libhttp-negotiate-perl libmission-control-plugins0 libnet-http-perl
libnss-myhostname libostree-1-1 librygel-core-2.6-2 librygel-db-2.6-2
librygel-renderer-2.6-2 librygel-renderer-gst-2.6-2 librygel-server-2.6-2
libsnapd-glib1 libtie-ixhash-perl libwww-robotrules-perl
libxml-xpathengine-perl lightsoff polari python3-cffi-backend python3-crypto
python3-cryptography python3-cups python3-idna python3-keyring
python3-keyrings.alt python3-lazr.uri python3-oauth python3-pyasn1
python3-secretstorage python3-simplejson python3-software-properties
python3-urllib3 python3-wadllib python3-zope.interface quadrapassel rygel
rygel-playbin rygel-tracker snapd-login-service swell-foop tali
telepathy-idle telepathy-logger telepathy-mission-control-5
ubuntu-system-service unattended-upgrades unity-control-center-faces
Use 'apt autoremove' to remove them.
The following NEW packages will be installed:
ca-certificates
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/167 kB of archives.
After this operation, 436 kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously unselected package ca-certificates.
(Reading database ... 265740 files and directories currently installed.)
Preparing to unpack .../ca-certificates_20170717~17.04.1_all.deb ...
Unpacking ca-certificates (20170717~17.04.1) ...
Processing triggers for man-db (2.7.6.1-2) ...
Setting up ca-certificates (20170717~17.04.1) ...
/var/lib/dpkg/info/ca-certificates.postinst: 147: /var/lib/dpkg/info/ca-certificates.postinst: update-ca-certificates: not found
dpkg: error processing package ca-certificates (--configure):
subprocess installed post-installation script returned error exit status 127
Errors were encountered while processing:
ca-certificates
E: Sub-process /usr/bin/dpkg returned an error code (1)
ca-certificates
ca-certificates
Fair enough :)
Okay's give this fella a go:
sudo dpkg-reconfigure ca-certificates
Your server really is not liking the ca-certificates :P
Thats really weird.
I could help you via teamviewer.
Never had such an error.
Fair enough :)
Your server really is not liking the ca-certificates :p
That looks more promising, I am not into it, but dpkg seems to handle things different to the normal installation over apt-get
root@vmd12916:~# sudo dpkg-reconfigure ca-certificates
/usr/sbin/dpkg-reconfigure: ca-certificates is broken or not fully installed
Thats really weird.
When the new idea from KosmicReeds does not change anything I would please this
apt-get purge ca-certificates && apt-get install ca-certificates && update-ca-certificates
