Sinusbot Installer Script
@Qhiliqq
alright so I did the "yum -y update", took quite a long time but it finished, tried to install bot and it did the same thing so I did "yum-complete-transaction" and that fixed it.
BUT, It is doing the same thing that it was on a different VPS, reason I got this new one was to test it.
What it does is after installing everything, Teamspeak server and then Sinusbot, If I reboot the server it won't come back online. seems to only happen after installing sinusbot.
I am going to create a bug thread about this now.
@Qhiliqq
More informations about this => https://forum.sinusbot.com/threads/sinusbot-vps-wont-boot-after-restart-isolated-i-think.4514/
@Qhiliqq
Nope, won't come back online and I either have to restore a backup (That doesn't have the SinusBot) (Haven't got any for new server as it's always a fresh install anyway) or do a re-image of the OS, therefore resulting in doing all this yum update stuff again, very frustrating.
I have posted a thread about it in the bugs section, but as I said there, I don't actually think it's the SinusBot, I think it has something to do with the servers I have.
Edit* By not to do with the SinusBot I mean I don't think its an error within SinusBot, But my VPS's themselves, I mean they reboot fine, just not after I install SinusBot, No idea why.
I'm using Ubuntu 17.10 and I have this error message:
Ausgabe wird nach »wget-log« umgeleitet.
Checking for the latest latet installer version
E: Sperrdatei /var/lib/dpkg/lock konnte nicht geöffnet werden. - open (13: Keine Berechtigung)
E: Sperren des Administrationsverzeichnissess (/var/lib/dpkg/) nicht möglich, sind ie root?
Error on line 64. Report this to the author at https://forum.sinubot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer cript. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L64
When I try to run the command with sudo I have this error message:
bash: /dev/fd/63: Datei oder Verzeichnis nicht gefunden
Thank you in advanc.
Installed systemd file to start the SinusBot with "service sinusbot {start|stop|        status|restart}"
Cronjob already set for SinusBot updater!
Installing YT-Downloader now!
Cronjob already set for YT-DL updater!
Downloading YT-DL now...
Download successful!
youtube-dl is up-to-date (2017.12.14)
Deleted /tmp/.sinusbot.lock
Deleted /tmp/.X11-unix/X40
Please wait... This will take some seconds!
/dev/fd/63: line 1063: /etc/init.d/sinusbot: No such file or directory
2017/12/19 16:00:46 X [MAIN] Starting up fake x-server...
Version: 0.11.0-8e5f1a2
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChanne        l.js
2017/12/19 16:00:46 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
a manual update is required
Error on line 1098. Report this to the author at https://forum.sinusbot.com/thre        ads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this i        s an error of your system not of the installer script. Or have a look directly t        o your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_i        nstaller.sh#L1098
debian 8 64 bit
reinstall (ger: neuinstallation)
Start installer now!
Detected latest TS3-Client version as 3.1.7
Packages installed!
TS3 already latest version.
Downloading latest SinusBot.
Extracting SinusBot files.
SinusBot update done.
Starting systemd installation
Installed systemd file to start the SinusBot with "service sinusbot {start|stop|status|restart}"
2017/12/19 16:13:13 X [MAIN] Starting up fake x-server...
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2017/12/19 16:13:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
Error on line 1098. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L1098
[Ger] Kleine Frage:
Und zwar läuft mein Sinusbot (2 aktive Bots auf Ts3) über meinen kleinen vServer (Debian 8 / 2gb ram) und verbraucht laut Konsole fast 60-70% des Arbeitsspeicher. Ist sehr viel und ich weiß auch net weiter.
Installiert habe ich des mit deinem Skript.
Korrigiert mich, wenn ich was dummes sage.
Mit freundlichen Grüßen
Senpai Mizu
debian 8 64 bit
Packages installed!
Deine Uhrzeit stimmt dann wohl nicht...
Wird abgefragt ob dein Datum so passt oder nicht. Bitte nochmals beim installieren genau anschauen.
Bei mir kommt folgender Fehler.
Error on line 248. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L248
Kann mir jemand weiterhelfen ?
Versuche mal bitte das manuell auszuführen:
Bash:
apt-get install debconf-utils
Bash:
Dann kommt das
root@m18rv34:/home# apt-get install debconf-utils
Reading package lists... Done
Building dependency tree
debconf-utils is already the newest version.
E: There are problems and -y was used without --force-yes
Error on line 259. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L259
Dann kommt das
Was für ein OS ist das denn?
Hello helpful folks,
just tried to install sinusbot on a fresh root server with Ubuntu 17.04.
The script is getting stuck at "Installing necessary packages. Please wait..." every time.
Has anybody an idea why?
Thanks in advance
Note: I did not install a fresh ts3 server, just copied my old one from the old root. Could this create difficulties?
root@vmd12916:~# bash <(wget --no-check-certificate -O - 'https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1514283089')
--2017-12-26 11:08:28-- https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1514283089
Length: 34270 (33K) [application/octet-stream]
Saving to: 'STDOUT'
- 0%[ ] 0 --.-KB/s Checking for the latest latest installer version
- 100%[===================>] 33.47K --.-KB/s in 0.005s
2017-12-26 11:08:29 (6.29 MB/s) - written to stdout [34270/34270]
Your installer is up-to-date.
You're using Installer 1.4
What should the Installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
/dev/fd/63: line 272: virt-what: command not found
/dev/fd/63: line 274: virt-what: command not found
1) Automatic
2) Own path
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
/dev/fd/63: line 542: virt-what: command not found
Check your time below:
DATE: 12/26/17
TIME: 11:08:47
1) Correct
2) Incorrect
#? 1
1) Yes
2) Try without
3) No
#? 1
@Ironeer
I don't think so, I moved from a CentOS server to Ubuntu by a complete backup and I had no problems.
Just wondering how long you left the install on 'Installing necessary packages'? As it can take a very long time, I found that Ubuntu is extremely slow compared to CentOS.
Regards.
@Ironeer
Regards.
At least I ran it for 2 hours :oops:
Thanks in advance
Saving to: 'STDOUT'
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Done!
1) Automatic
2) Own path
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
DATE: 12/26/17
TIME: 11:08:47
1) Correct
2) Incorrect
#? 1
1) Yes
2) Try without
3) No
#? 1
On a fresh install this could take more than 10 minutes cause of the fresh installation. Many hosters doesn't update der ISOs so the system have to download all missing files and install them.
Also the internet conmection could be the problem.
Run the installer and wait maybe hours. It doesn't got stuck.
You could also run this and check it yourself:
apt-get install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 curl less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 -y
update-ca-certificates
@Ironeer
Regards.
Exactly. Most times this is caused by the hosters which doesn't update their installisos...
What he said :)
As example, with the place I have my VPS they install the 'bare minimum' and expect you to install everything yourself, most places do this.
I'm lucky it is on a very fast network so it only took roughly 15 minutes or less to install the whole bot. (Bolck of the waiting was where you are up to)
Thanks for your quick help, I think you're perfectly right because I did not update anything:confused:
I just ran the command but got an Error while processing ntp, after that the script showed the same error
root@vmd12916:~# apt-get install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 curl less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 -y
bzip2 is already the newest version (1.0.6-8.1).
dbus is already the newest version (1.10.10-1ubuntu2).
iproute2 is already the newest version (4.9.0-1ubuntu1).
less is already the newest version (481-2.1ubuntu2).
libasound2 is already the newest version (1.1.3-5).
libasound2 set to manually installed.
libglib2.0-0 is already the newest version (2.52.0-1).
libglib2.0-0 set to manually installed.
psmisc is already the newest version (22.21-2.1build1).
python is already the newest version (2.7.13-2).
python set to manually installed.
screen is already the newest version (4.5.0-5ubuntu1).
x11-xkb-utils is already the newest version (7.7+3).
x11-xkb-utils set to manually installed.
ca-certificates is already the newest version (20170717~17.04.1).
ca-certificates set to manually installed.
curl is already the newest version (7.52.1-4ubuntu1.4).
libegl1-mesa is already the newest version (17.0.7-0ubuntu0.17.04.1).
libegl1-mesa set to manually installed.
libnss3 is already the newest version (2:3.28.4-0ubuntu0.17.04.3).
libnss3 set to manually installed.
libxcursor1 is already the newest version (1:1.1.14-1ubuntu0.17.04.1).
libxcursor1 set to manually installed.
The following additional packages will be installed:
dma liblockfile-bin liblockfile1 libopts25 libvncclient1 libvncserver1
x11vnc-data
Suggested packages:
ntp-doc
The following NEW packages will be installed:
cron-apt dma liblockfile-bin liblockfile1 libopts25 libvncclient1
libvncserver1 ntp x11vnc x11vnc-data xvfb
0 upgraded, 11 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/2,838 kB of archives.
After this operation, 7,810 kB of additional disk space will be used.
Preconfiguring packages ...
Selecting previously unselected package liblockfile-bin.
(Reading database ... 267443 files and directories currently installed.)
Preparing to unpack .../00-liblockfile-bin_1.14-1_amd64.deb ...
Unpacking liblockfile-bin (1.14-1) ...
Selecting previously unselected package liblockfile1:amd64.
Preparing to unpack .../01-liblockfile1_1.14-1_amd64.deb ...
Unpacking liblockfile1:amd64 (1.14-1) ...
Selecting previously unselected package libopts25:amd64.
Preparing to unpack .../02-libopts25_1%3a5.18.12-3_amd64.deb ...
Unpacking libopts25:amd64 (1:5.18.12-3) ...
Selecting previously unselected package ntp.
Preparing to unpack .../03-ntp_1%3a4.2.8p9+dfsg-2ubuntu1.2_amd64.deb ...
Unpacking ntp (1:4.2.8p9+dfsg-2ubuntu1.2) ...
Selecting previously unselected package cron-apt.
Preparing to unpack .../04-cron-apt_0.10.0_all.deb ...
Unpacking cron-apt (0.10.0) ...
Selecting previously unselected package dma.
Preparing to unpack .../05-dma_0.11-1_amd64.deb ...
Unpacking dma (0.11-1) ...
Selecting previously unselected package libvncclient1:amd64.
Preparing to unpack .../06-libvncclient1_0.9.11+dfsg-1_amd64.deb ...
Unpacking libvncclient1:amd64 (0.9.11+dfsg-1) ...
Selecting previously unselected package libvncserver1:amd64.
Preparing to unpack .../07-libvncserver1_0.9.11+dfsg-1_amd64.deb ...
Unpacking libvncserver1:amd64 (0.9.11+dfsg-1) ...
Selecting previously unselected package x11vnc-data.
Preparing to unpack .../08-x11vnc-data_0.9.13-2_all.deb ...
Unpacking x11vnc-data (0.9.13-2) ...
Selecting previously unselected package x11vnc.
Preparing to unpack .../09-x11vnc_0.9.13-2_amd64.deb ...
Unpacking x11vnc (0.9.13-2) ...
Selecting previously unselected package xvfb.
Preparing to unpack .../10-xvfb_2%3a1.19.3-1ubuntu1.3_amd64.deb ...
Unpacking xvfb (2:1.19.3-1ubuntu1.3) ...
Setting up x11vnc-data (0.9.13-2) ...
Setting up liblockfile-bin (1.14-1) ...
Setting up cron-apt (0.10.0) ...
Setting up libvncserver1:amd64 (0.9.11+dfsg-1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu2) ...
Setting up xvfb (2:1.19.3-1ubuntu1.3) ...
Setting up liblockfile1:amd64 (1.14-1) ...
Setting up libvncclient1:amd64 (0.9.11+dfsg-1) ...
Setting up dma (0.11-1) ...
Creating config file /etc/dma/dma.conf with new version
Processing triggers for libc-bin (2.24-9ubuntu2.2) ...
Processing triggers for systemd (232-21ubuntu7.1) ...
Setting up libopts25:amd64 (1:5.18.12-3) ...
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for gnome-menus (3.13.3-6ubuntu5) ...
Setting up x11vnc (0.9.13-2) ...
Setting up ntp (1:4.2.8p9+dfsg-2ubuntu1.2) ...
/var/lib/dpkg/info/ntp.postinst: 22: /var/lib/dpkg/info/ntp.postinst: addgroup: not found
dpkg: error processing package ntp (--configure):
subprocess installed post-installation script returned error exit status 127
Errors were encountered while processing:
ntp
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@vmd12916:~# apt-get install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 curl less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 -y update-ca-certificates
E: Unable to locate package update-ca-certificates
cron-apt is already the newest version (0.10.0).
x11vnc is already the newest version (0.9.13-2).
ntp is already the newest version (1:4.2.8p9+dfsg-2ubuntu1.2).
xvfb is already the newest version (2:1.19.3-1ubuntu1.3).
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
ntp
root@vmd12916:~# --configure
bash: --configure: command not found
root@vmd12916:~# ntp --configure
bash: ntp: command not found
root@vmd12916:~# bash <(wget --no-check-certificate -O - 'https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1514286302')
--2017-12-26 11:55:10-- https://sinusbot-installer.de/download.php?s=fd594f3b79734d8a1438ec50d9de3d40&t=1514286302
Saving to: 'STDOUT'
- 100%[===================>] 33.47K --.-KB/s in 0s
2017-12-26 11:55:10 (306 MB/s) - written to stdout [34270/34270]
ntp
Can you try just 'apt-get update' and see if you receive the same error?
Note that this command may take a long time as well.
