Sinusbot Installer Script
I have a problem with this :
Error on line 770. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: "su -c "wget -q https://www.sinusbot.com/dl/sinusbot.current.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread.
What should i do ? I have server on linux ubuntu 16.04
A mistake popped up in the console.
"Error on line 770. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: "su -c "wget -q https://www.sinusbot.com/dl/sinusbot.current.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread." ???????
I can't reproduce the error on Ubuntu 16.04.
Could you download it in a random folder?
wget https://www.sinusbot.com/dl/sinusbot.current.tar.bz2
Does a error come up? If yes post it here please.
Now i have server on Debian 9 and have this problem too
--2018-03-10 20:56:59-- https://www.sinusbot.com/dl/sinusbot.current.tar.bz2
Resolving www.sinusbot.com (www.sinusbot.com)... 104.18.40.220, 104.18.41.220
Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.40.220|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2018-03-10 20:56:59 ERROR 403: Forbidden.
Hmm thats weird...
@mxschmitt @flyth
Debian 9 - ERROR
Error on line 261. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " apt-get -qq install debconf-utils -y". Please try to execute it manually and attach the output to the bug report in the forum thread.
I think your dpkg is broken...
Does
apt-get install debconf-utils
work?
If no send us the output here.
debian 9 error
i cant install sinusbot
See
Command which failed was: "su -c "tar -xjf sinusbot.current.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread.
What should i do ?
What should i do ?
Switch to your install dir and your sinusbot user after that try "tar -xjf sinusbot.current.tar.bz2".
If there is a error, restart the installer and remove sinusbot first.
Something is wrong w/ the download site, can't download the script... first there is an SSL certificate error which even if you go past, it takes me to a hosting sign in page.
Error on line 770. Report this to the author at https://forum.sinusbot.com/threa ds/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: "su -c "wget -q https://www.sinusbot.com/dl/sinusbot.c urrent.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread.
i need help
@flyth @mxschmitt
Of course you can.
it works like a charme, update your dns ;)
Bei der Installation kann man ja auswählen, ob Sinusbot nur für Discord oder für beides installiert werden soll.
Wenn ich nur Discord angebe, ist es dann möglich 2 Instanzen mit Discord zu kriegen.
Und wenn ja, wie installiert man so etwas manuell mit nur Discord?
Ja das geht und manuell ist eher schwierig (TS3PATH in der config leer lassen bei dem ersten Start)
Error on line 623. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " apt-get -y -qq install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 >/dev/null". Please try to execute it manually and attach the output to the bug report in the forum thread.
Help me please :(
