Sinusbot Installer Script
Version: 0.13.37-9791176
2018/02/24 02:42:13 X [MAIN] Starting up fake x-server...
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2018/02/24 02:42:13 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
a manual update is required
Error on line 1058.
Error on line 1058.
Check your server time, this will be asked while installing, if you check "yes" without checking your time, we can't help, just retry the installer...
Or if this is not the solution, update the bot as it said...
My Servertime is current and correct
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Error on line 72. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " apt-get -qq install wget -y". Please try to execute it manually and attach the output to the bug report in the forum thread.
ubuntu 16.04 on vps
hello I have an error when I run an update
this message is displayed to me
Starting the installer now!
Packages installed!
Failed to set ntp: Activation of org.freedesktop.timedate1 timed out
Error on line 657. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: "      timedatectl set-ntp yes". Please try to execute it manually and attach the output to the bug report in the forum thread.
what is wrong?
Packages installed!
what is wrong?
Have you tried to execute the command? What is the output?
Guy you sent me a peace of code, did you read that before sending it? If yes, then read again "Command which failed: ..." ;)
This is the Error nach of the command "timedatectl set-ntp yes"
Failed to set ntp: Unit systemd-timedated.service is masked.
I have a Problem.
Error on line 623. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " apt-get -y -qq install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 >/dev/null". Please try to execute it manually and attach the output to the bug report in the forum thread.
I have a Problem.
execute it manually:
apt-get -y install screen x11vnc xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute2 dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6
to see which error comes up
