I have problem, please help.
W: Failed to fetch http://mirrors.digitalocean.com/ubuntu/dists/trusty-updates/InRelease Unable to find expected entry 'main/binary-i 3860/Packages' in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://mirrors.digitalocean.com/ubuntu/dists/trusty-backports/InRelease Unable to find expected entry 'main/binary -i3860/Packages' in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://mirrors.digitalocean.com/ubuntu/dists/trusty-security/InRelease Unable to find expected entry 'main/binary- i3860/Packages' in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/Release Unable to find expected entry 'universe/binary-i3860/Package s' in Release file (Wrong sources.list entry or malformed file)
W: Failed to fetch http://mirrors.digitalocean.com/ubuntu/dists/trusty/Release Unable to find expected entry 'main/binary-i3860/Packa ges' in Release file (Wrong sources.list entry or malformed file)
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a P N or a bad review, cause this is an error of your system not of the installer script. Line 266.
Script installer not working, tried the manual but got no luck
Dann nimm spaßeshalber mal nen anderen.Der Port ist frei, auch nach einem Neustart reagiert er auf den Port nicht. Freigeben ist der Port auch...
READ!!! (Guy please use your brainhelp !!!
HTTP request sent, awaiting response... 403 Link expired, reload the site and try again
2019-03-21 17:36:15 ERROR 403: Link expired, reload the site and try again.
Hey, bei mir kommt immer dieser fehlerWas kann ich tun?W: Failed to fetch http://ftp.debian.org/debian/dists/wheezy-backports/main/binary-amd64/Packages 404 Not Found [IP: 130.89.148.12 80]
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 266.
Wie ist der befehl dazu?ich würde mal /var/lib/apt/lists/ löschen und neu draufpacken
Nein geht immer noch nicht.apt-get clean
rm -rf /var/lib/apt/lists/*
apt-get clean
apt-get update
apt-get upgrade
cat /etc/apt/sources.list
Ich benutzte Debian 8
mv /etc/apt/sources.list /etc/apt/souces.list.old
vi /etc/apt/sources.list
apt-get update
und gleicher fehler beim installer script?deb http://ftp.debian.org/debian jessie main contrib
# deb http://ftp.debian.org/debian jessie-updates main contrib
# deb http://security.debian.org jessie/updates main contrib
deb http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
# deb-src http://ppa.launchpad.net/webupd8team/java/ubuntu xenial main
deb http://ftp.debian.org/debian wheezy-backports main
# deb-src http://ftp.debian.org/debian wheezy-backports main
deb [arch=amd64] https://download.docker.com/linux/debian jessie stable
# deb-src [arch=amd64] https://download.docker.com/linux/debian jessie stable
deb http://repo.ajenti.org/debian main main debian
das gibt sie aus
liegt auf jeden fall an deiner sources.list. Setze ansonsten deinen Server neu auf.dass kommt beim script
