Sinusbot Installer Script
Problem Solved just do it :| all noobs
Just need 2 steps
Example my country date
date -s "8 JUL 2017 19:42:15"
hwclock --set --date="2017-07-08 19:43:15" --localtime
Finished And Solved All problem bye
dear
Wenn ich es installiere kommt jedes mal der Selbe errror :c
Error on line 582. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L582
Es gab schonmal einen thread über dieses problem mit deiner Antwort
Steht noch etwas davor?
Denn das which Tool wird einen Schritt vorher installier, falls es fehlen sollte.
Ich habe keine Ahnung, was das "which tool" ist oder was ich hier machen muss. Bitte helfen sie mir!!
Bei mir kommt folgende Meldung:
Error on line 898. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L898
Mach das:
Just need 2 steps
dear
Welches OS? Which wird nur bei Centos installiert: apt-get install which
./sinusbot_installer.sh: line 569: magentaMessag: command not found
Error on line 569. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L569
root@vmd18170:/opt#
Hello i have Debian 8 and the script say to me:
Is your error the same as this one:
root@vmd18170:/opt#
Can't find an error in the script, in line 569 is written
magentaMessage "Installing necessary packages! Please wait..."
, not "magentaMessag"...
The script say: /dev/fd/63: line 569: magentaMessag: command not found
root@vmd18170:/opt#
Found the error, try again :)
hey guys i have this problem when i installed sinusbot on my CentOS 7 server it gave me the "Unauthorized" error if i want to login as admin (tried to re install everything and using temp passwd) still didn't work.. anyone can help? I even tried the PW Reset command...
ty
He stops after he answers the questions. Can you please help?
Note: I am using version 17.04 x64 of Ubuntu.
