Which version do I need to get good?Buy a new Server or delete your one. Totally misconfigured or broken at all.
Update the bot to fix the next-bugI am still waiting for a reply regarding the problems i'm experiencing. My reply no: #656
Okay I'll make a new post next time. Btw I've tried updating both the bot and youtube-dl 4 times and even tried reinstalling it 2 times but i keep on getting the same issue. I've also tried restarting, stopping and starting sinusbot service. Restarting the VPS but still no luck.Update the bot to fix the next-bug
Update youtube-dl.
And this thread sholdn't be used for posting issues that don't have anything to do with the installer. You should just start a new one if you want a reply.
Qhiliqq hat eine neue Ressource erstellt:
Sinusbot Installer Script - Install latest Sinusbot, TS3-Client and YT-DL.
Weitere Informationen zu dieser Ressource...
2017/06/25 00:54:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2017/06/25 00:54:10 X [MAIN] Starting up fake x-server...
a manual update is required
Error on line 985. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L985
	This is not a installer problem...I'm not sure if the problem I'm getting is sinusbot related or script related. Anyway, I am experiencing few problems lately. Firstly, I can't seem to access the "Addons" tab under settings. Secondly, I'm getting an error: "Could not playback the selected file / stream". I get this error when trying to play a song using a YT-DL playlist and lastly, "!next" command does nothing anymore as the instant i write "!next", the sound of the bot(music) is gone and next song never starts even though on the webinterface, the song is still playing and after that i can't manually play a song using webinterface as i get the aforementioned error stating that "Could not playback the selected file / stream". After sinusbot restart, song resumes. Weird!
Wrong thread.Updating the bot and youtube-dl didn't helped me. Any more suggestions?
Installed with script? If yes open up your eyes there are many informations and a readme, if not, wrong thread.How to restart the SinusBOT so that the YT-DL can work
Help Me!![]()
ntpd: unrecognized service
Error on line 889. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L889
	Should be fixed, try again.I am getting this error:
Code:Generated README_installer.txt! ntpd: unrecognized service Error on line 889. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L889
Steht noch etwas davor?Hi, ich habe ein Problem, nämlich wirft der Sinusbot-Installer mir eine Fehlermeldung beim Installieren.
Error on line 582. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L582
Ich würde mich über jegliche Hilfe freunen
MfG Dengli
Sollte gefixt sein.Ich bekommen beim installieren mit dem script (https://sinusbot-installer.de/) einen error:
Failed to set ntp: Message did not receive a reply (timeout by message bus)
- 79%[====================================================================> ] 23.63K 549 B/s in 44s
Cannot write to '-' (Broken pipe).
root@v4030:~#
HILFE!!!
