Sinusbot Installer Script
Qhiliqq
Licensed Partner
Moin,
Hätte eine frage,ist es möglich das dass Script auf die ältere TS Vision Updatet? Hab ja aktuell 3.0.19.4
Und empfohlen wird ja aktuell 3.0.18.2.
MFG
Das macht der Installer automatisch.
I have a problem with my sinusbot installation. When I try to install, the error message ''Failed to read the password, try a reinstall again"
I have looked around the internet, and only found answers on here. But there didn't seem a clear solution to this.
Can you help me with this?
More informations please. Which OS?
Error on line 1055. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: http
You got an error while changing to your installation.
Check manually: yourlocation/sinusbot
Is this file existing?
Ritchi
I am experiencing the same issue.
Ammar
I'm getting this error. I have CentOS 6.7 64bit
fantahund99
root@mc:/home# ./sinusbot_installer.sh
Setting up mysql-server-5.5 (5.5.57-0+deb8u1) ...
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.)
debconf: falling back to frontend: Readline
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 150: logger: command not found
ATTENTION: An error has occured. More info is in the syslog!
/var/lib/dpkg/info/mysql-server-5.5.postinst: line 240: logger: command not found
dpkg: error processing package mysql-server-5.5 (--configure):
subprocess installed post-installation script returned error exit status 127
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.5; however:
Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
mysql-server-5.5
mysql-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
Error on line 64. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L64
root@mc:/home#
Qhiliqq
Licensed Partner
E: Unable to locate package virt-what
Error on line 64
I tried the manual install. Same error. I'm running Debian 8
apt-get install virt-what
throws that error?
CentOS6 is not supported.
I include something to check this and cancle the installation.
mysql-server-5.5
mysql-server
root@mc:/home#
Try manual apt-get install virt-what
And which OS?
fantahund99
root@mc:/home# apt-get install virt-what
Reading package lists... Done
Building dependency tree
virt-what is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Abort.
mysql-server-5.5
mysql-server
root@mc:/home#
my OS : Debian 8.8 (minimal)
Qhiliqq
Licensed Partner
Abort.
mysql-server-5.5
mysql-server
root@mc:/home#
And manual apt-get install wget^^ Guy read that line ^^ there is the error...
Knoxxar
Ich bekomme folgenden Error beim updaten der youtube-dl:
Error while downloading youtube-dl with cURL. Trying it with wget.
Error on line 928. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L928
Qhiliqq
Licensed Partner
Probier mal manuell:
wget -O /usr/local/bin/youtube-dl http://yt-dl.org/downloads/latest/youtube-dl
wenn es geht lösche die datei wieder und versuche es nochmals mit dem installer.
evtl. fehlt dir auch wget als paket, was aber eigentlich installiert werden sollte.
Brini
Wäre es eigentlich auch möglich ein Auto-Update System mit einzubauen, was den Bot automatisch immer auf dem neusten Stand hält?
Bandes
Hab seit Heute diesen Fehler
Sinusbot could not start! Starting it directly. Look for errors!
Could not open /tmp/.sinusbot.lock. Is SinusBot already running?
was kann das sein ?
Qhiliqq
Licensed Partner
Hey, ich habe schon wieder ein Error bei der Installation Error on line 64 :(
Na dann schau doch mal nach was in der Zeile gemacht wird, deshalb schick ich auch den Link mit github mit ;)
Wenns an
schon hängt ^^
