einfach den genannten befehl mal ausführenSorry stehte gerade total auf den Schlauch![]()
I don't know what a system you got.
Sorry my bad. I accidently wrote Debian instead of Ubuntu. I got confused as I have a lot of machines.I don't know what a system you got.
This is a normal debian package.
Every system you reported got a unnormal error.
Whats your hoster?
I changed the way of installation a little bit, but on every machine I tested, it works, cause this is a normal debian package.Sorry my bad. I accidently wrote Debian instead of Ubuntu. I got confused as I have a lot of machines.
The above error occurred on blazingfast.io's VPS running Ubuntu Server 16.04 LTS 64 bit.
I have machines from OVH, blazingfast, 3 different OVH resellers, ramnode, leaseweb and few small unknown sellers.
Well, I run Sinusbot instances on "big/known" providers and idk why I keep on getting these errors. So now you can't reproduce the error which means you won't be able to help me. I know you're a busy guy, but If you want, I can give you access to my blazingfast VPS so that you can sort this out maybe?I changed the way of installation a little bit, but on every machine I tested, it works, cause this is a normal debian package.
Blazingfast use KVM virtualization so the normal ovz failure shouldn't come up with this.
I really don't know whats the problem on your machines...
You wrote many machines with errors I can't reproduce.
Schau mal ob in dem Verzeichnis wo der Installer gestartet wurde eine "virt-what_1.14-1_amd64.deb" Datei liegt, wenn ja führe folgendes aus:Moin,
Bekomme den Fehler..
Error on line 249. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L249
Jemand an PLan?
dpkg -i ./virt-what_1.14-1_amd64.deb
Schau mal ob in dem Verzeichnis wo der Installer gestartet wurde eine "virt-what_1.14-1_amd64.deb" Datei liegt, wenn ja führe folgendes aus:Ich gehe davon aus, dass dein System noch einen anderen package Prozess in betrieb hatte und somit eine installation blockiert wird.Code:dpkg -i ./virt-what_1.14-1_amd64.deb
Na dann führe doch mal Zeile 64 ausJa Hab ich gemacht.
Bekomme jetzt die Fehler Meldung.
Error on line 64. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L64
Verstehe es nicht, weil es ist einfach so gekommen.sonst laufen die Bots sauber.
apt-get install wget -y
More informations please... OS?Hey i get this error what is this??
TS3Client reported missing dependencies for xcb. Please install xcb and try again. On Ubuntu / Debian you can usually as root run: apt-get install xcb i have instlled xcb not working still
You really used the installer? Sure?Its ubuntu 17.04 and centos 7-6 all os 1 gb ram
Still same error after i install xcb
apt-get install x11vnc xvfb libxcursor1 ca-certificates libglib2.0-0 bzip2
apt-get update && apt-get upgrade && apt-get dist-upgrade
I'll check this on ubuntu 17.04.yes
Its on a vps tho
Which OS?
systemctl enable sinusbot.service
Your bot can't start. Switch to your sinusbot user and in it's installation directory. Start the bot manual with ./sinusbot and look for errors.Hi, I'm trying to install sinusbot in my VPS Ubuntu 16.04 but it gives me this error: Error on line 1072. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L1072
su sinusbot
cd /opt/sinusbot
./sinusbot
