can I somehow make it so that the installer skips this step?Can't reply this.
Download works at my testservers...
Try a reinstall.
Try a reinstall.
Please answer first my questioncan I somehow make it so that the installer skips this step?
I do not see that you asked me a question. I tried to reinstall, did not help, i don't know where are your test serversPlease answer first my question![]()
Ouh excuse me wrong userI do not see that you asked me a question. I tried to reinstall, did not help, i don't know where are your test servers
wget https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.40.220|:443... connected.Ouh excuse me wrong user
But I really can't reproduce the error.
Are you able to download the sinusbot via?Code:wget https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
Maybe I implement a skip, but there is no ETA for this![]()
useError on line 1065. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L1065
Ask your hoster, or try manual install.Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.40.220|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2017-10-26 19:30:53 ERROR 403: Forbidden.
because you have the script in the first place "curl -I https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2", through which I can not download
root@v32635:~# curl -I https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
HTTP/1.1 403 Forbidden
followed by curl -O -s https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2, through which I essentially download
i don't know why i cant download
Hier wird lediglich eine Nachricht angezeigt, dass hierbei ein Fehler kommt ist merkwürdig.Könnt Ihr mir da helfen?Code:useError on line 1065. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L1065
ManuallyError while downloading with cURL (Status = 403). Trying it with wget.
Error on line 804. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L804
I'm not able to fix this atm...wget https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
--2017-10-28 20:36:01-- https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
Resolving www.sinusbot.com (www.sinusbot.com)... 104.18.41.220, 104.18.40.220
Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.41.220|:443... connected.
2017-10-28 20:36:02 ERROR 403: Forbidden.
Where is your VPS located? And which hoster? Just for knowledge.I'm looking forward to the solution I am writing through Google Translator, thanks in advance for the help
vps Ukraine Kharkov https://vps.ua/Where is your VPS located? And which hoster? Just for knowledge.
debian 8 cleanWhere is your VPS located? And which hoster? Just for knowledge.
And I've no idea which OS you usingError on line 859. https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L859
i have no idea why
@NUGOSS I can't fix your problem atm.
Try installing the bot manually.
And I've no idea which OS you using![]()
Which error is shown above my error text?Debian 8 ist my OS
