Gestern um 22:54 Uhr
Servus,
Du hätte mal eine Frage. Bei mir waren auf einmal alle Bots down. Warum auch immer. Dachte mir dann lass mal dein Script drüber laufen um zu schauen ob es vll. ein Update gibt oder so. Aber wenn ich das mache bekomme ich die Fehlermeldung:
2018/10/22 16:56:29 X [MAIN] Starting up fake x-server...
Version: 0.14.3-0e747fd
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin Advanced Display Playback Information.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin ServerRules.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin SteamUserQuery.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin avatarbanner.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin reconnect.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/10/22 16:56:29 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
a manual update is required
Command which failed was: " su -c "$LOCATION/sinusbot" $SINUSBOTUSER". Please try to execute it manually and attach the output to te bug report in the forum thread.
If it still doesn't work report this to the author at
https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not aPN or a bad review, cause this is an error of your system not of the installer script. Line 1097.
