Hallo ich brauche mal hilfe ich habe leider keine arnung von linux benutze es nur für den bot habe bei der instalation einen fehler beckommen und weis nicht weiter
Command which failed was: "    apt-get upgrade". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at
https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 597.
root@LXC_NAME:/home/admin# systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
   Active: failed (Result: exit-code) since Sat 2018-11-24 14:00:22 UTC; 48s ago
     Docs: man:bluetoothd(8)
  Process: 10398 ExecStart=/usr/lib/bluetooth/bluetoothd (code=exited, status=1/FAILURE)
Main PID: 10398 (code=exited, status=1/FAILURE)
   Status: "Starting up"
Nov 24 14:00:22 LXC_NAME bluetoothd[10398]: Bluetooth daemon 5.23
Nov 24 14:00:22 LXC_NAME bluetoothd[10398]: Failed to access management inte...e
Nov 24 14:00:22 LXC_NAME bluetoothd[10398]: Adapter handling initialization ...d
Nov 24 14:00:22 LXC_NAME systemd[1]: bluetooth.service: main process exited...RE
Nov 24 14:00:22 LXC_NAME systemd[1]: Failed to start Bluetooth service.
Nov 24 14:00:22 LXC_NAME systemd[1]: Unit bluetooth.service entered failed ...e.
Hint: Some lines were ellipsized, use -l to show in full.
root@LXC_NAME:/home/admin# -l
bash: -l: command not found
root@LXC_NAME:/home/admin# systemcl status bluetooth.service
bash: systemcl: command not found
   Active: failed (Result: exit-code) since Sat 2018-11-24 14:00:22 UTC; 4min 8s ago
Könnte ich da hilfe beckommen
Mfg
