I get this error when i update my sinusbot:
It says me this:
bash: /sinusbot: No such file or directory
The "could not contact update server" error most likely results from your IP getting blacklisted. This can have multiple reasons:
- You have been running multiple Sinusbot processes on your server (to run more than 2 instances of the bot)
- You are sharing your IP with someone else, who is doing the above.
- Someone already did that with the IP your currently having.
Schon probiert den Sinusbot manuell zu starten? (ohne das installer Script)Hey,
####GERMAN####
Es hat bisher alles geklappt mit der Installation. Ich habe dazu nichts im Forum gefunden. Deswegen frage ich hier. Bei mir steht am ende: "Failed to read password, try a reinstall again." Ich habe es mehrmals versucht. Dennoch erfolglos.
####ENGLISH####
Everything has worked so far with the installation. I have not found anything in the forum. That's why I'm asking here. For me, at the end: "Failed to read password, try a reinstall again." I have tried it several times. Nevertheless unsuccessful.
HELP ME![]()
Das wird hier nichts bringen, denke ich.Schon probiert den Sinusbot manuell zu starten? (ohne das installer Script)
Maybe @flyth could do something, but this is not a problem with my installer.Hello.
Can you unblock my ip please ?
Since people for some reason started talking through photos / screenshots..
// EDIT
But okay, run these commands as root:
cd /etc/apt
nano sources.list // paste the output here
and then:
cd /etc/apt/sources.list.d
ls // paste the output from this here
Debian 9 (Stretch)Holy smokes ... what a mess ... Sinusbot and the messed up VPSs - Part 629
(This is a Linux problem btw - not Sinusbot or the installer, prolly caused by a cheap and/or missconfigurated vps)
Which OS are you running actually (is it Debian 9 or Ubuntu)?
Remove every single file from that folder, that has ubuntu in it's name,Debian 9 (Stretch)
It works! Thank you a lotRemove every single file from that folder, that has ubuntu in it's name,
the mono probably too, I do not exactly know what it is, if you want you can first try installing Sinusbot after removing just ubuntu files and then if it won't work, remove the mono too.
So, remove everything inside the folder I guess.
And then try to install Sinusbot again.
2019-07-21T22:34:57+02:00 closing channels
2019-07-21T22:34:56+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-21T22:34:56+02:00 Closed.
2019-07-21T22:34:56+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-07-21T22:34:56+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-07-21T22:34:56+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-07-21T22:34:56+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-07-21T22:34:56+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-07-21T22:34:56+02:00 TS>/home/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /home/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019-07-21T22:34:56+02:00 Starting instance ts3server://IPCENSORED?port=9987&nickname=HKBot&password=&channel=&channelpassword=
2019-07-21T22:34:56+02:00 Could not insert into News-Tableno such table: News
2019-07-21T22:34:56+02:00 Could not delete from Newsno such table: News
2019-07-21T22:34:56+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-07-21T22:34:56+02:00 Could not delete from Profilesno such table: Profiles
2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application
2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application
2019-07-21T22:34:56+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-21T22:34:56+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-21T22:34:56+02:00 Could not create Chat-Tabletable Chat already exists
2019-07-21T22:34:56+02:00 About to run.
There is something wrong with your TS3 client, you are 3rd guy reporting this error in 3 days, weird.Hey, they installer went through without problems, but i cant connect the bot to a server.
I hope someone got an solution.
Instance Log:
Code:2019-07-21T22:34:57+02:00 closing channels 2019-07-21T22:34:56+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details. 2019-07-21T22:34:56+02:00 Closed. 2019-07-21T22:34:56+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom 2019-07-21T22:34:56+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled 2019-07-21T22:34:56+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot' 2019-07-21T22:34:56+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present 2019-07-21T22:34:56+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first 2019-07-21T22:34:56+02:00 TS>/home/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /home/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5) 2019-07-21T22:34:56+02:00 Starting instance ts3server://IPCENSORED?port=9987&nickname=HKBot&password=&channel=&channelpassword= 2019-07-21T22:34:56+02:00 Could not insert into News-Tableno such table: News 2019-07-21T22:34:56+02:00 Could not delete from Newsno such table: News 2019-07-21T22:34:56+02:00 Could not insert into News-Tableno such table: News 2019-07-21T22:34:56+02:00 Could not delete from Newsno such table: News 2019-07-21T22:34:56+02:00 Could not insert into News-Tableno such table: News 2019-07-21T22:34:56+02:00 Could not delete from Newsno such table: News 2019-07-21T22:34:56+02:00 Could not insert into Profiles-Tableno such table: Profiles 2019-07-21T22:34:56+02:00 Could not delete from Profilesno such table: Profiles 2019-07-21T22:34:56+02:00 Could not insert into Profiles-Tableno such table: Profiles 2019-07-21T22:34:56+02:00 Could not delete from Profilesno such table: Profiles 2019-07-21T22:34:56+02:00 Could not insert into Profiles-Tableno such table: Profiles 2019-07-21T22:34:56+02:00 Could not delete from Profilesno such table: Profiles 2019-07-21T22:34:56+02:00 Could not insert into Profiles-Tableno such table: Profiles 2019-07-21T22:34:56+02:00 Could not delete from Profilesno such table: Profiles 2019-07-21T22:34:56+02:00 Could not insert into Profiles-Tableno such table: Profiles 2019-07-21T22:34:56+02:00 Could not delete from Profilesno such table: Profiles 2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not delete from FileTransferno such table: FileTransfer 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not insert into Application-Tableno such table: Application 2019-07-21T22:34:56+02:00 Could not delete from Applicationno such table: Application 2019-07-21T22:34:56+02:00 Could not create Notifications-Tabletable Notifications already exists 2019-07-21T22:34:56+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists 2019-07-21T22:34:56+02:00 Could not create Chat-Tabletable Chat already exists 2019-07-21T22:34:56+02:00 About to run.
Try: chown -R sinusbot:sinusbot /opt/sinusbot/
(adjust path and sinusbot user to your own)
If it won't work, check if you installed it correctly, try to repeat every step or something, but the problem is with TS3 client.
// Maybe you can also try this, if you didn't do it chmod 755 sinusbot (in your sinusbot dir)
Weird :/ We need to wait for someone more experienced than me. Already 3 guys reported this issue and no one solved it yet.Sadly that didn't fix it.
I already tried to reinstall the whole thing, but that didn't help either
