But you can still open the website, can't you?Hey i just wanted to inform you that your Cert is expired or not valid atm on https://sinusbot-installer.de/ "SEC_ERROR_EXPIRED_CERTIFICATE"
regards
regards
2019-07-26T15:10:28+02:00 Storing configuration.
2019-07-26T15:10:19+02:00 closing channels
2019-07-26T15:10:18+02:00 Closed.
2019-07-26T15:10:18+02:00 TSClient quit.
2019-07-26T15:10:18+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-07-26T15:10:18+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-07-26T15:10:18+02:00 TS>QStandardPaths: wrong ownership on runtime directory /tmp/runtime-sinusbot, 1000 instead of 1003
2019-07-26T15:10:18+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-07-26T15:10:18+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-07-26T15:10:18+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-07-26T15:10:09+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Bidon&password=&channel=&channelpassword=
2019-07-26T15:10:04+02:00 Could not insert into News-Tableno such table: News
2019-07-26T15:10:04+02:00 Could not delete from Newsno such table: News
2019-07-26T15:10:04+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-07-26T15:10:04+02:00 Could not delete from Profilesno such table: Profiles
2019-07-26T15:10:04+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-07-26T15:10:04+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-07-26T15:10:04+02:00 Could not insert into Application-Tableno such table: Application
2019-07-26T15:10:04+02:00 Could not delete from Applicationno such table: Application
2019-07-26T15:10:04+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-26T15:10:04+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-26T15:10:04+02:00 Could not create Chat-Tabletable Chat already exists
So, how can I update it?means that your kernel version is too old for TS 3.3.0 ... version 3.17 or higher is required!Code:terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
https://forum.sinusbot.com/threads/ts-client-3-3-0-problem.7172/#post-41079So, how can I update it?
Btw, it was working like 2 weeks ago.
Here is output
/dev/fd/63: line 1012: /etc/init.d/sinusbo
--2019-08-04 08:08:39-- https://sinusbot-installer.de/download.php?s=c604d368ac3e9d22f6d329c7e97fe17f&t=1564906591
Resolving sinusbot-installer.de (sinusbot-installer.de)... 144.76.68.94
Connecting to sinusbot-installer.de (sinusbot-installer.de)|144.76.68.94|:443... connected.
HTTP request sent, awaiting response... 500 Internal Server Error
2019-08-04 08:08:39 ERROR 500: Internal Server Error.
Leider nicht, die 500er Fehler liegen eigentlich immer im Verantwortungsbereich des Servers.Kann man mir dabei helfen?
We have not used a 32 bit version since the script was written.after updating yesterday my bot seems to be broken because it is installing a 64bit instance of teamspeak.
2019-08-06T17:04:16-04:00 eof from voice
2019-08-06T17:04:16-04:00 eof from data
2019-08-06T17:04:16-04:00 closing channels
2019-08-06T17:04:15-04:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-08-06T17:04:15-04:00 Closed.
2019-08-06T17:04:15-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019-08-06T17:04:15-04:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=RM%27s%20Jukebox%201&password=2702&channel=&channelpassword=
2019-08-06T17:04:15-04:00 About to run.
2019-08-06T17:04:15-04:00 Prespawn.
2019-08-06T17:04:09-04:00 BOT-CONFIG [admin] NICK NAME PASSWORD CHANPW CHAN ANNOUNCE DESCRIPTION ANNOUNCESTR TTSURL CC OK
2019-08-06T17:01:44-04:00 Storing configuration.
2019-08-06T17:01:16-04:00 eof from voice
2019-08-06T17:01:16-04:00 closing channels
2019-08-06T17:01:15-04:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-08-06T17:01:15-04:00 Closed.
2019-08-06T17:01:15-04:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: error while loading shared libraries: libXss.so.1: cannot open shared object file: No such file or directory
2019-08-06T17:01:15-04:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-08-06T17:01:15-04:00 About to run.
2019-08-06T17:01:15-04:00 Fail from voice reader: read unix @->@: use of closed network connection
2019-08-06T17:01:15-04:00 Fail from data reader: read unix @->@: use of closed network connection
2019-08-06T17:01:15-04:00 closing channels
2019-08-06T17:01:14-04:00 Prespawn.
2019-08-06T17:01:14-04:00 script command loaded
2019-08-06T17:01:14-04:00 module registered as command
2019-08-06T17:01:14-04:00 registered callback for event chat
2019-08-06T17:01:14-04:00 serialized function: true
2019-08-06T17:01:14-04:00 Auto-Starting 1e7bbd57-40bc-434c-8ece-aa1619801e8e/1f235ba6-fe4d-4605-9238-bb758b3490e6 in 500 ms...
2019-08-06T17:01:14-04:00 Initialization complete
2019-08-06T17:01:14-04:00 executing script command
2019-08-06T17:01:14-04:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-08-06T17:01:14-04:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
apt-get install libxss1
Command which failed was: " yum -y update". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 593.
[root@sv power]# yum -y update
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* epel: mirror.freethought-internet.co.uk
* remi: remi.mirror.ate.info
* remi-php55: remi.mirror.ate.info
* remi-php56: remi.mirror.ate.info
* remi-php72: remi.mirror.ate.info
* remi-safe: remi.mirror.ate.info
* remi-test: remi.mirror.ate.info
Resolving Dependencies
--> Running transaction check
---> Package MariaDB-client.x86_64 0:10.2.25-1.el7.centos will be updated
---> Package MariaDB-client.x86_64 0:10.2.26-1.el7.centos will be an update
---> Package MariaDB-common.x86_64 0:10.2.24-1.el7.centos will be updated
---> Package MariaDB-common.x86_64 0:10.2.26-1.el7.centos will be an update
---> Package MariaDB-compat.x86_64 0:10.2.24-1.el7.centos will be updated
---> Package MariaDB-compat.x86_64 0:10.2.26-1.el7.centos will be an update
---> Package MariaDB-server.x86_64 0:10.2.25-1.el7.centos will be updated
---> Package MariaDB-server.x86_64 0:10.2.26-1.el7.centos will be an update
---> Package beamium.noarch 0:1.9.3-3 will be updated
---> Package beamium.noarch 0:2.0.2-1 will be an update
---> Package bind.x86_64 32:9.9.4-73.el7_6 will be updated
---> Package bind.x86_64 32:9.9.4-74.el7_6.2 will be an update
---> Package bind-libs.x86_64 32:9.9.4-73.el7_6 will be updated
---> Package bind-libs.x86_64 32:9.9.4-74.el7_6.2 will be an update
---> Package bind-libs-lite.x86_64 32:9.9.4-73.el7_6 will be updated
---> Package bind-libs-lite.x86_64 32:9.9.4-74.el7_6.2 will be an update
---> Package bind-license.noarch 32:9.9.4-73.el7_6 will be updated
---> Package bind-license.noarch 32:9.9.4-74.el7_6.2 will be an update
---> Package bind-utils.x86_64 32:9.9.4-73.el7_6 will be updated
---> Package bind-utils.x86_64 32:9.9.4-74.el7_6.2 will be an update
---> Package composer.noarch 0:1.8.5-1.el7.remi will be updated
---> Package composer.noarch 0:1.9.0-1.el7.remi will be an update
---> Package cpp.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package cpp.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package curl.x86_64 0:7.29.0-51.el7 will be updated
---> Package curl.x86_64 0:7.29.0-51.el7_6.3 will be an update
---> Package device-mapper.x86_64 7:1.02.149-10.el7_6.3 will be updated
---> Package device-mapper.x86_64 7:1.02.149-10.el7_6.8 will be an update
---> Package device-mapper-event.x86_64 7:1.02.149-10.el7_6.3 will be updated
---> Package device-mapper-event.x86_64 7:1.02.149-10.el7_6.8 will be an update
---> Package device-mapper-event-libs.x86_64 7:1.02.149-10.el7_6.3 will be updated
---> Package device-mapper-event-libs.x86_64 7:1.02.149-10.el7_6.8 will be an update
---> Package device-mapper-libs.x86_64 7:1.02.149-10.el7_6.3 will be updated
---> Package device-mapper-libs.x86_64 7:1.02.149-10.el7_6.8 will be an update
---> Package exim.x86_64 0:4.91-3.el7 will be updated
---> Package exim.x86_64 0:4.92-1.el7 will be an update
---> Package gcc.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package gcc.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package gcc-c++.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package gcc-c++.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package gcc-gfortran.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package gcc-gfortran.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package ghostscript.x86_64 0:9.07-31.el7_6.10 will be updated
---> Package ghostscript.x86_64 0:9.07-31.el7_6.11 will be an update
---> Package glib2.x86_64 0:2.56.1-2.el7 will be updated
---> Package glib2.x86_64 0:2.56.1-4.el7_6 will be an update
---> Package glibc.x86_64 0:2.17-260.el7_6.4 will be updated
---> Package glibc.x86_64 0:2.17-260.el7_6.6 will be an update
---> Package glibc-common.x86_64 0:2.17-260.el7_6.4 will be updated
---> Package glibc-common.x86_64 0:2.17-260.el7_6.6 will be an update
---> Package glibc-devel.x86_64 0:2.17-260.el7_6.4 will be updated
---> Package glibc-devel.x86_64 0:2.17-260.el7_6.6 will be an update
---> Package glibc-headers.x86_64 0:2.17-260.el7_6.4 will be updated
---> Package glibc-headers.x86_64 0:2.17-260.el7_6.6 will be an update
---> Package iproute.x86_64 0:4.11.0-14.el7 will be updated
---> Package iproute.x86_64 0:4.11.0-14.el7_6.2 will be an update
---> Package kernel-4.19-ovh-mod-std-ipv6-64-headers.x86_64 0:4.19_ovh_mod_std_ipv6_64-840029 will be obsoleting
---> Package kernel-4.19-ovh-xxxx-pcs-ipv6-64-headers.x86_64 0:4.19_ovh_xxxx_pcs_ipv6_64-818445 will be obsoleting
---> Package kernel-4.19-ovh-xxxx-std-ipv6-64-headers.x86_64 0:4.19_ovh_xxxx_std_ipv6_64-840029 will be obsoleting
---> Package kernel-4.19-ovh-xxxx-std-ipv6-64-hz1000-headers.x86_64 0:4.19_ovh_xxxx_std_ipv6_64_hz1000-732421 will be obsoleting
---> Package kernel-debug-devel.x86_64 0:3.10.0-957.10.1.el7 will be updated
---> Package kernel-debug-devel.x86_64 0:3.10.0-957.27.2.el7 will be an update
---> Package kernel-headers.x86_64 0:3.10.0-957.10.1.el7 will be obsoleted
---> Package kexec-tools.x86_64 0:2.0.15-21.el7 will be updated
---> Package kexec-tools.x86_64 0:2.0.15-21.el7_6.4 will be an update
---> Package libcurl.x86_64 0:7.29.0-51.el7 will be updated
---> Package libcurl.x86_64 0:7.29.0-51.el7_6.3 will be an update
---> Package libgcc.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libgcc.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libgfortran.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libgfortran.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libgomp.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libgomp.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libidn2.x86_64 0:2.1.1a-1.el7 will be updated
---> Package libidn2.x86_64 0:2.2.0-1.el7 will be an update
---> Package libquadmath.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libquadmath.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libquadmath-devel.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libquadmath-devel.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libssh2.x86_64 0:1.4.3-12.el7_6.2 will be updated
---> Package libssh2.x86_64 0:1.4.3-12.el7_6.3 will be an update
---> Package libstdc++.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libstdc++.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libstdc++-devel.x86_64 0:4.8.5-36.el7_6.1 will be updated
---> Package libstdc++-devel.x86_64 0:4.8.5-36.el7_6.2 will be an update
---> Package libteam.x86_64 0:1.27-5.el7 will be updated
---> Package libteam.x86_64 0:1.27-6.el7_6.1 will be an update
---> Package lvm2.x86_64 7:2.02.180-10.el7_6.3 will be updated
---> Package lvm2.x86_64 7:2.02.180-10.el7_6.8 will be an update
---> Package lvm2-libs.x86_64 7:2.02.180-10.el7_6.3 will be updated
---> Package lvm2-libs.x86_64 7:2.02.180-10.el7_6.8 will be an update
---> Package nginx.x86_64 1:1.14.2-1.el7_4.ngx will be updated
---> Package nginx.x86_64 1:1.16.0-1.el7.ngx will be an update
---> Package ovh-rtm-binaries.noarch 0:1.0.2-1 will be updated
---> Package ovh-rtm-binaries.noarch 0:1.0.3-1 will be an update
---> Package ovh-rtm-metrics-toolkit.noarch 0:1.0.4_1-1 will be updated
---> Package ovh-rtm-metrics-toolkit.noarch 0:1.0.6-1 will be an update
---> Package ovhkernel_4.9_xxxx_std_ipv6.x86_64 0:4.9.168_xxxx_std_ipv6_64-665790 will be updated
---> Package ovhkernel_4.9_xxxx_std_ipv6.x86_64 0:4.9.185_xxxx_std_ipv6_64-799710 will be an update
---> Package pango.x86_64 0:1.42.4-1.el7 will be updated
---> Package pango.x86_64 0:1.42.4-2.el7_6 will be an update
---> Package php.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-bcmath.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-bcmath.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-cli.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-cli.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-common.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-common.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-composer-ca-bundle.noarch 0:1.1.4-1.el7.remi will be updated
---> Package php-composer-ca-bundle.noarch 0:1.2.3-1.el7.remi will be an update
---> Package php-composer-spdx-licenses.noarch 0:1.5.1-1.el7.remi will be updated
---> Package php-composer-spdx-licenses.noarch 0:1.5.2-1.el7.remi will be an update
---> Package php-composer-xdebug-handler.noarch 0:1.3.2-1.el7.remi will be updated
---> Package php-composer-xdebug-handler.noarch 0:1.3.3-1.el7.remi will be an update
---> Package php-gd.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-gd.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-gmp.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-gmp.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-google-recaptcha.noarch 0:1.2.1-1.el7.remi will be updated
---> Package php-google-recaptcha.noarch 0:1.2.2-1.el7.remi will be an update
---> Package php-imap.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-imap.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-intl.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-intl.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-json.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-json.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-kolab-net-ldap3.noarch 0:1.0.7-2.el7.remi will be updated
---> Package php-kolab-net-ldap3.noarch 0:1.1.0-1.el7.remi will be an update
---> Package php-ldap.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-ldap.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-masterminds-html5.noarch 0:2.3.0-1.el7.remi will be updated
---> Package php-masterminds-html5.noarch 0:2.6.0-1.el7.remi will be an update
---> Package php-mbstring.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-mbstring.x86_64 0:7.2.21-1.el7.remi will be an update
--> Processing Dependency: libonig.so.5()(64bit) for package: php-mbstring-7.2.21-1.el7.remi.x86_64
---> Package php-mysqlnd.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-mysqlnd.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-paragonie-random-compat.noarch 0:2.0.12-1.el7.remi will be updated
---> Package php-paragonie-random-compat.noarch 0:2.0.18-1.el7.remi will be an update
---> Package php-pdo.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-pdo.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-pear.noarch 1:1.10.9-2.el7.remi will be updated
---> Package php-pear.noarch 1:1.10.9-3.el7.remi will be an update
---> Package php-phpmyadmin-sql-parser.noarch 0:4.3.1-1.el7.remi will be updated
---> Package php-phpmyadmin-sql-parser.noarch 0:4.3.2-1.el7.remi will be an update
---> Package php-phpseclib.noarch 0:2.0.15-1.el7.remi will be updated
---> Package php-phpseclib.noarch 0:2.0.21-1.el7.remi will be an update
---> Package php-process.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-process.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-pspell.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-pspell.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-recode.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-recode.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-soap.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-soap.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-symfony-browser-kit.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-browser-kit.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-class-loader.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-class-loader.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-common.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-common.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-config.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-config.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-console.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-console.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-css-selector.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-css-selector.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-debug.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-debug.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-dependency-injection.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-dependency-injection.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-dom-crawler.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-dom-crawler.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-event-dispatcher.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-event-dispatcher.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-expression-language.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-expression-language.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-filesystem.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-filesystem.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-finder.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-finder.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-http-foundation.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-http-foundation.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-http-kernel.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-http-kernel.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-process.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-process.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-var-dumper.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-var-dumper.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony-yaml.noarch 0:2.8.51-1.el7.remi will be updated
---> Package php-symfony-yaml.noarch 0:2.8.51-2.el7.remi will be an update
---> Package php-symfony3-common.noarch 0:3.4.26-1.el7.remi will be updated
---> Package php-symfony3-common.noarch 0:3.4.29-1.el7.remi will be an update
---> Package php-symfony3-options-resolver.noarch 0:3.4.26-1.el7.remi will be updated
---> Package php-symfony3-options-resolver.noarch 0:3.4.29-1.el7.remi will be an update
---> Package php-symfony3-translation.noarch 0:3.4.26-1.el7.remi will be updated
---> Package php-symfony3-translation.noarch 0:3.4.29-1.el7.remi will be an update
---> Package php-tidy.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-tidy.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-twig.noarch 0:1.39.1-1.el7.remi.7.2 will be updated
---> Package php-twig.noarch 0:1.42.2-1.el7.remi.7.2 will be an update
---> Package php-xml.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-xml.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package php-xmlrpc.x86_64 0:7.2.17-1.el7.remi will be updated
---> Package php-xmlrpc.x86_64 0:7.2.21-1.el7.remi will be an update
---> Package phpMyAdmin.noarch 0:4.8.5-1.el7.remi will be updated
---> Package phpMyAdmin.noarch 0:4.9.0.1-1.el7.remi will be an update
---> Package python.x86_64 0:2.7.5-77.el7_6 will be updated
---> Package python.x86_64 0:2.7.5-80.el7_6 will be an update
---> Package python-devel.x86_64 0:2.7.5-77.el7_6 will be updated
---> Package python-devel.x86_64 0:2.7.5-80.el7_6 will be an update
---> Package python-libs.x86_64 0:2.7.5-77.el7_6 will be updated
---> Package python-libs.x86_64 0:2.7.5-80.el7_6 will be an update
---> Package python-perf.x86_64 0:3.10.0-957.10.1.el7 will be updated
---> Package python-perf.x86_64 0:3.10.0-957.27.2.el7 will be an update
---> Package python2-pip.noarch 0:8.1.2-8.el7 will be updated
---> Package python2-pip.noarch 0:8.1.2-9.el7 will be an update
---> Package rsync.x86_64 0:3.1.2-4.el7 will be updated
---> Package rsync.x86_64 0:3.1.2-6.el7_6.1 will be an update
---> Package selinux-policy.noarch 0:3.13.1-229.el7_6.9 will be updated
---> Package selinux-policy.noarch 0:3.13.1-229.el7_6.15 will be an update
---> Package selinux-policy-targeted.noarch 0:3.13.1-229.el7_6.9 will be updated
---> Package selinux-policy-targeted.noarch 0:3.13.1-229.el7_6.15 will be an update
---> Package sysstat.x86_64 0:10.1.5-17.el7 will be updated
---> Package sysstat.x86_64 0:10.1.5-17.el7_6.1 will be an update
---> Package systemd.x86_64 0:219-62.el7_6.5 will be updated
---> Package systemd.x86_64 0:219-62.el7_6.9 will be an update
---> Package systemd-libs.x86_64 0:219-62.el7_6.5 will be updated
---> Package systemd-libs.x86_64 0:219-62.el7_6.9 will be an update
---> Package systemd-sysv.x86_64 0:219-62.el7_6.5 will be updated
---> Package systemd-sysv.x86_64 0:219-62.el7_6.9 will be an update
---> Package teamd.x86_64 0:1.27-5.el7 will be updated
---> Package teamd.x86_64 0:1.27-6.el7_6.1 will be an update
---> Package tuned.noarch 0:2.10.0-6.el7_6.3 will be updated
---> Package tuned.noarch 0:2.10.0-6.el7_6.4 will be an update
---> Package tzdata.noarch 0:2019a-1.el7 will be updated
---> Package tzdata.noarch 0:2019b-1.el7 will be an update
---> Package vim-common.x86_64 2:7.4.160-5.el7 will be updated
---> Package vim-common.x86_64 2:7.4.160-6.el7_6 will be an update
---> Package vim-enhanced.x86_64 2:7.4.160-5.el7 will be updated
---> Package vim-enhanced.x86_64 2:7.4.160-6.el7_6 will be an update
---> Package vim-filesystem.x86_64 2:7.4.160-5.el7 will be updated
---> Package vim-filesystem.x86_64 2:7.4.160-6.el7_6 will be an update
---> Package vim-minimal.x86_64 2:7.4.160-5.el7 will be updated
---> Package vim-minimal.x86_64 2:7.4.160-6.el7_6 will be an update
---> Package oniguruma5.x86_64 0:6.9.2-2.el7.remi will be installed
--> Finished Dependency Resolution
