Sinusbot Installer Script
As I said, with OpenVZ you can do nothing at all, since kernel can only be upgraded by the hoster. So you have to ask him.
FAQ said:
When choosing a VPS (virtual private server), make sure that it is not based on OpenVZ, because the Linux kernel will be too old. Instead choose a KVM or LCX based VPS with a recent OS.
i tried to do it manually but he gave me an error
[root@Archedia ~]# yum -y install screen xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute which dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1
CentOS-8 - AppStream 18 kB/s | 4.3 kB 00:00
CentOS-8 - Base 12 kB/s | 3.9 kB 00:00
CentOS-8 - Extras 5.4 kB/s | 1.5 kB 00:00
Extra Packages for Enterprise Linux Modular 8 - x86_64 65 kB/s | 34 kB 00:00
Extra Packages for Enterprise Linux 8 - x86_64 58 kB/s | 30 kB 00:00
Remi's Modular repository for Enterprise Linux 8 - x86_64 42 kB/s | 3.5 kB 00:00
Safe Remi's RPM repository for Enterprise Linux 8 - x86_64 33 kB/s | 3.0 kB 00:00
Package screen-4.6.2-10.el8.x86_64 is already installed.
No match for argument: xvfb
No match for argument: libxcursor1
Package ca-certificates-2019.2.32-80.0.el8_1.noarch is already installed.
Package bzip2-1.0.6-26.el8.x86_64 is already installed.
Package psmisc-23.1-3.el8.x86_64 is already installed.
No match for argument: libglib2.0-0
Package less-530-1.el8.x86_64 is already installed.
No match for argument: cron-apt
No match for argument: ntp
No match for argument: python
There are following alternatives for "python": python2, python36
Package iproute-4.18.0-15.el8.x86_64 is already installed.
Package which-2.21-10.el8.x86_64 is already installed.
Package dbus-1:1.12.8-9.el8.x86_64 is already installed.
No match for argument: libnss3
No match for argument: libegl1-mesa
No match for argument: x11-xkb-utils
No match for argument: libasound2
No match for argument: libxcomposite-dev
No match for argument: libxi6
No match for argument: libpci3
No match for argument: libxslt1.1
No match for argument: libxkbcommon0
No match for argument: libxss1
Error: Unable to find a match: xvfb libxcursor1 libglib2.0-0 cron-apt ntp python libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1
[root@Archedia ~]#
Hey Frostoloh,
i have the same Problem with my own Server and this Sinusbot-installscript. The Solution is pretty easy, but i dont think its in your favor.
The conclusion is you using the latest CentOS Release "8" and this script didnt really support it. All those packages cant be installed in your current OS with just an "dnf install XXXXX".
You have to wipe your Server completly and run it on CentOS "7" or workaround the packages and try to fix it yourself (good luck...).
Checking for the latest installer version
/dev/fd/63: line 92: 3: No such file or directory
You're using installer 1.5
What should the installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
E: Package 'debconf-utils' has no installation candidate
Command which failed was: " apt-get install debconf-utils -y". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 264.
root@vps-zap468432-1:~# apt-get install debconf-utils -y
Reading package lists... Done
Building dependency tree
Package debconf-utils is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
debconf-i18n
help pls
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
debconf-i18n
help pls
In case your native language is English:
https://forum.sinusbot.com/threads/read-me-before-you-post.342/
Falls du deutsch kannst:
https://forum.sinusbot.com/threads/lies-mich-bevor-du-schreibst.146/
Natürlich ist es in diesem Fall kein stumpfes kopieren und einfügen.
Aber mit DOWNLOAD_URL ist die Teamspeak Client url gemeint.
Versuch mal folgende Befehle als ROOT. Vorausgesetzt du hast im Installer Script den Benutzer "sinusbot" genannt oder einfach leer gelassen!
Ansonsten musst du natürlich "sinusbot" dann in den befehlen abändern.
cd /opt/sinusbot/teamspeak3-client
su -c "wget https://files.teamspeak-services.com/releases/client/3.5.3/TeamSpeak3-Client-linux_amd64-3.5.3.run" sinusbot
Ok Danke habe es die nacht dan doch noch irgendwie hinbekommen
hey, i tried installing sinusbot on my linux system (ubuntu), i used the installer and it said everything was fine but it said that the sinusbot could not start, i opened a new terminal tab and typed in the command to start it and it said that there was no service.sinusbot file found, or something like that, ill join the discord later to tell u exactly what happened
bialy, heres the link for the pastebin, thats inside the terminal https://pastebin.com/5FyrmG9J
To use the script, the command should look like this as root!
bash <(wget -O - 'https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh')
not wget -O - 'https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh'
Hello, i have a problem whit the automatic script installation. Below is the error script.
Command which failed was: " update-ca-certificates". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 632.
Just execute the command
