Sinusbot Installer Script
You need to fix your apt repositorys of your system.
(For example Proxmox and Spotify and some opther repos are causing your problems)
(i use centos8 and i can't change operating system)
Please help!!
[root@Archedia ~]# bash <(wget -O - 'https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh')
Redirecting output to 'wget-log.5'.
Checking for the latest installer version
/dev/fd/63: line 92: 3: No such file or directory
You're using installer 1.5
What should the installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
Installing redhat-lsb! Please wait.
Done!
You're running CentOS. Which firewallsystem are you using?
1) IPtables
2) Firewalld
#? 2
Warning, your server is running OpenVZ! This very old container system isn't well supported by newer packages.
Automatically chosen system.d for your startscript!
1) Automatic
2) Own path
3) Quit
#? 1
Should I install TeamSpeak or only Discord Mode?
1) Both
2) Only Discord
3) Quit
#? 1
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
Update the system packages to the latest version? (Recommended)
1) Yes
2) No
#? 1
Starting the installer now!
Detected latest TS3-Client version as 3.3.2
Error: Unable to find a match: xvfb libxcursor1 libglib2.0-0 cron-apt ntp python libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1
Command which failed was: " yum -y install screen xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute which dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 622.
Please read again ... (I highlighted you the important part, in case you missed it)
Then act accordingly. :)
And please post uname -a bcause you are using OpenVZ. This could maybe be a problem using Sinusbot with TS3
i tried to do it manually but he gave me an error
[root@Archedia ~]# yum -y install screen xvfb libxcursor1 ca-certificates bzip2 psmisc libglib2.0-0 less cron-apt ntp python iproute which dbus libnss3 libegl1-mesa x11-xkb-utils libasound2 libxcomposite-dev libxi6 libpci3 libxslt1.1 libxkbcommon0 libxss1
CentOS-8 - AppStream 18 kB/s | 4.3 kB 00:00
CentOS-8 - Base 12 kB/s | 3.9 kB 00:00
CentOS-8 - Extras 5.4 kB/s | 1.5 kB 00:00
Extra Packages for Enterprise Linux Modular 8 - x86_64 65 kB/s | 34 kB 00:00
Extra Packages for Enterprise Linux 8 - x86_64 58 kB/s | 30 kB 00:00
Remi's Modular repository for Enterprise Linux 8 - x86_64 42 kB/s | 3.5 kB 00:00
Safe Remi's RPM repository for Enterprise Linux 8 - x86_64 33 kB/s | 3.0 kB 00:00
Package screen-4.6.2-10.el8.x86_64 is already installed.
No match for argument: xvfb
No match for argument: libxcursor1
Package ca-certificates-2019.2.32-80.0.el8_1.noarch is already installed.
Package bzip2-1.0.6-26.el8.x86_64 is already installed.
Package psmisc-23.1-3.el8.x86_64 is already installed.
No match for argument: libglib2.0-0
Package less-530-1.el8.x86_64 is already installed.
No match for argument: cron-apt
No match for argument: ntp
No match for argument: python
There are following alternatives for "python": python2, python36
Package iproute-4.18.0-15.el8.x86_64 is already installed.
Package which-2.21-10.el8.x86_64 is already installed.
Package dbus-1:1.12.8-9.el8.x86_64 is already installed.
No match for argument: libnss3
No match for argument: libegl1-mesa
No match for argument: x11-xkb-utils
No match for argument: libasound2
No match for argument: libxcomposite-dev
No match for argument: libxi6
No match for argument: libpci3
No match for argument: libxslt1.1
No match for argument: libxkbcommon0
No match for argument: libxss1
[root@Archedia ~]#
Das ist ein Problem seitens youtube-dl, hat nichts mit dem SinusBot, und erst recht nichts mit dem Installer zu tun.
Einfach mal die Foren Suche bemühen, da findet man einiges.
Ich weiß nicht ob ich es einfach nicht sehe, kann man den Sinusbot auf einem bereits existierendem Ts3 Server installieren? Bei der automatischen Installation wird ja direkt ein Teamspeak-Client mitinstalliert, jedoch möchte ich dies nicht.
Gibt es da eine Lösung?
Weshalb möchtest du denn keinen TeamSpeak-Client?
Generell wirst du ohne einen Client i.A. nicht auf einen Server connecten können! Da dies auch für TS gilt, wäre somit die Antwort, nein. ;)
Natürlich lässt sich der Bot zB. auf den gleichen VPS installieren, aber dafür ist das hier nicht der richtige Thread.
Hi, when I try to include the sinusbot I get this error message: "Command failed:" apt-get update ". Try to run it manually and attach the output to the bug report in the forum thread." Even after executing the registered command it persists.
Read the error message again carefully! ...attach the output to the bug report...
Further information may also be useful. click
Hallo kann mir jemand helfen?
Wenn ich den Befehl für das scrip ausführe, bekomme ich folgende Meldung:
root@WaffelBrot:/home# bash <(wget -O - 'https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh')
Redirecting output to ‘wget-log.1’.
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
E: The repository 'http://ppa.launchpad.net/linuxuprising/java/ubuntu groovy Release' does not have a Release file.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 263.
root@WaffelBrot:/home# apt-get update
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Ign:4 http://ppa.launchpad.net/linuxuprising/java/ubuntu groovy InRelease
Err:5 http://ppa.launchpad.net/linuxuprising/java/ubuntu groovy Release
404 Not Found [IP: 2001:67c:1560:8008::15 80]
Reading package lists... Done
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
2020-05-18T20:23:39+10:00 closing channels
2020-05-18T20:23:38+10:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-05-18T20:23:38+10:00 Closed.
2020-05-18T20:23:38+10:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2020-05-18T20:23:38+10:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2020-05-18T20:23:38+10:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2020-05-18T20:23:38+10:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2020-05-18T20:23:38+10:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-05-18T20:23:38+10:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2020-05-18T20:23:38+10:00 TS |INFO |Addons | |Checking for addon updates...
2020-05-18T20:23:38+10:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2020-05-18T20:23:38+10:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2020-05-18T20:23:38+10:00 TS |DEBUG |PulseAudio | |connected to pulse audio server -
2020-05-18T20:23:38+10:00 TS |INFO | | |Using hardware aes
2020-05-18T20:23:38+10:00 TS |INFO | | |SystemInformation: Linux 3.16.0-10-amd64 #1 SMP Debian 3.16.81-1 (2020-01-17) x86_64 Binary: 64bit
2020-05-18T20:23:38+10:00 TS |INFO | | |TeamSpeak Client 3.5.3 (2020-05-06 09:07:50)
2020-05-18T20:23:38+10:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/dd5f3c05-0b26-42e0-8dac-aceb3e1a2d7b/ef72c174-4ec2-477b-948f-db13fbc7c0f7/crashdumps
2020-05-18T20:23:38+10:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/dd5f3c05-0b26-42e0-8dac-aceb3e1a2d7b/ef72c174-4ec2-477b-948f-db13fbc7c0f7/crashdumps
how can u fix that with out wiping the server?
The question is whether you can fix it yourself at all.
Are you having an OpenVZ or KVM server? Only with the latter you can upgrade the kernel by yourself, otherwise it's up to your hoster.
