yes, i'm root and ca-certificates are installed, but if i write update-ca-certificates this appens:are you root
try to install
thanks! Now it works I used su - instead of su thank you for the helpwell, it seems like not installed or not root
but one other thing could be:
if you use "su" instead of "su -" you don't have the root paths in your session.
see pm-bash: sed -i 's/YoutubeDLPath = ""/YoutubeDLPath = "\/ usr\/local\/bin\/youtube-dl"/g' /config.ini: File o directory doesn't exist
I fixt it by removing Line 682 in the Script (3065347476.png). Not the best way but it worked.Hey i can´t update my Sinusbot using this Script i becomme the Error "Failed to set ntp: NTP not supported"(3107014175.png) (208747693.png) i use Debian GNU/Linux bullseye/sid(1089908319.png) (3188654253.png)
Not an installer problem. Your apt php installation is broken.fix it yourself
MoinHallo Zusammen,
wollte gerade Sinusbot updaten leider wird mir die Fehlermeldung angezeigt.
Command which failed was: "chmod 750 -R $LOCATION". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 752.
Guten Morgen,Moin
was passiert, wenn du den Command, mit dem Pfad von deinem Sinusbot-Verzeichnis anstelle von $LOCATION, manuell ausführst?
