Masterowicz
I can't find solution to fix my problem. I just reinstalled sinusbot by using your script from this site: https://sinusbot-installer.de/
My Specs:
SinusBot version: 1.0.0-beta.3-735814e
TS3 Client version: 3.3.0
Server version: 3.9.1
OS: Debian 9 64 bit
Hardware specs: VPS on net-speak.pl OpenVZ XL
Plugins: Youtube-dl
Please help me!
My Specs:
OS: Debian 9 64 bit
Plugins: Youtube-dl
2019-07-24T02:36:01+02:00 closing channels
2019-07-24T02:36:01+02:00 eof from voice
2019-07-24T02:36:00+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-07-24T02:36:00+02:00 Closed.
2019-07-24T02:36:00+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-07-24T02:36:00+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-07-24T02:36:00+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-07-24T02:36:00+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-07-24T02:36:00+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-07-24T02:36:00+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-07-24T02:36:00+02:00 Could not insert into News-Tableno such table: News
2019-07-24T02:36:00+02:00 Could not delete from Newsno such table: News
2019-07-24T02:36:00+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-07-24T02:36:00+02:00 Could not delete from Profilesno such table: Profiles
2019-07-24T02:36:00+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-07-24T02:36:00+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-07-24T02:36:00+02:00 Could not insert into Application-Tableno such table: Application
2019-07-24T02:36:00+02:00 Could not delete from Applicationno such table: Application
2019-07-24T02:36:00+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-07-24T02:36:00+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-07-24T02:36:00+02:00 Could not create Chat-Tabletable Chat already exists
2019-07-24T02:36:00+02:00 About to run.
- Operating System: Debian GNU/Linux 9.9 (stretch) (OpenVZ)
- Kernel: Linux 2.6.32-042stab133.2 x86_64
- Load Average: 0.14 0.25 0.26
- Uptime: 0 days, 0 hours, 55 minutes, 49 seconds
- OS APT Last Update: 23.07.2019 23:43:52 UTC +00:00:00
- Shell Locale: (not set)
- RAM: B/4.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 1.48 GB/25.00 GB in use (5%)
- libglib: 2.50.3-2
- Status: running (PIDs: 25970 25969, User: sinusbot)
- Webinterface: port locally reachable (Port: 8080)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.07.16)
linux-vdso.so.1 (0x00007ffea8550000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f9dc78b3000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f9dc755b000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f9dc715a000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f9dc67f5000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f9dc6581000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9dc6375000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9dc606f000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9dc5e52000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9dc5ad0000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9dc58b9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9dc551a000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9dc5300000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9dc50f6000)
/lib64/ld-linux-x86-64.so.2 (0x0000559daae21000)
- Time (local): 24.07.2019 00:38:51 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.07.16
- libglib: 2.50.3-2
- Timezone: Etc/UTC
ListenPort = 8080
ExternalFileBase = ""
LicenseKey = "3cHK7qbw3Ofk9OtmtfNDGLBFQY494Qrb02GQCxZZMxw="
DevMode = false
[TTS]
Enabled = false
ListenPort = 8080
DevMode = false
[TTS]
Enabled = false
