Sinusbot Installer Script
Hello i got this problem when updating Sinusbot.
- 100%[===================>] 33.06K --.-KB/s in 0.007s
2017-11-04 04:05:06 (4.54 MB/s) - written to stdout [33850/33850]
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Error on line 64. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L64
You have to use the user root, or another installation is still running.
Which error is shown above my error text?
I have the same error as "PPM". Also on Debian 8.
TS3 already latest version.
Downloading latest SinusBot.
Extracting SinusBot files.
SinusBot update done.
Starting systemd installation
Error on line 859. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L859
Try manually
systemctl daemon-reload
Some errors?
when I try to backup I get this error: BACKUP DIRECTORY NOT EXISTS. EXIT! what do I have to do? do I have to create a backup directory? if yes where?
dmidecode is a standard program in linux.
Which OS?
Backup? My script doesn't make backups? o_O
I saw this inside the script and I tought it makes backups
# Usage: /etc/init.d/sinusbot {start|stop|status|restart|console|update|backup} #
# - start: start the bot #
# - stop: stop the bot #
# - status: display the status of the bot (down or up) #
# - restart: restart the bot #
# - console: display the bot console #
# - update: runs the bot updater (with start & stop)
# - backup: archives your bot root directory
# To exit the console without stopping the server, press CTRL + A then D. #
I see.
Never tested that out :D It was a script made months ago.
Edit /etc/init.d/sinusbot DIR_BACKUP to a backupdirectory for your files to use that command.
Error on line 724. Report this to the author at https://forum.sinusbot.com/threa ds/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Or have a look directly to your error: https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_in staller.sh#L724
https://github.com/Sinusbot/installer-linux/blob/master/sinusbot_installer.sh#L724
OS?
Try
groupadd hereyoursinusbotuser
Who knows what this is? i can't run the sinusbot. Its says 'Failed To Read Password'
hbd274
http://prntscr.com/hbd274
Hi. Very nice script. But unfortunately I get this error today:
Setting up oracle-java7-installer (7u80+7u60arm-0~webupd8~1) ...
Downloading Oracle Java 7...
--2017-11-19 21:39:35--  http://download.oracle.com/otn-pub/java/jdk/7u80-b15/jdk-7u80-linux-x64.tar.gz
Resolving download.oracle.com (download.oracle.com)... 78.11.252.19, 78.11.252.43
Connecting to download.oracle.com (download.oracle.com)|78.11.252.19|:80... connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
Location: https://edelivery.oracle.com/otn-pub/java/jdk/7u80-b15/jdk-7u80-linux-x64.tar.gz [following]
--2017-11-19 21:39:35--  https://edelivery.oracle.com/otn-pub/java/jdk/7u80-b15/jdk-7u80-linux-x64.tar.gz
Resolving edelivery.oracle.com (edelivery.oracle.com)... 23.59.110.4, 2a02:26f0:f:19d::2d3e, 2a02:26f0:f:18e::2d3e
Connecting to edelivery.oracle.com (edelivery.oracle.com)|23.59.110.4|:443... connected.
Location: http://download.oracle.com/otn-pub/java/jdk/7u80-b15/jdk-7u80-linux-x64.tar.gz?AuthParam=1511124096_835cdc26cbf72802dd13c280b505542e [following]
--2017-11-19 21:39:36--  http://download.oracle.com/otn-pub/java/jdk/7u80-b15/jdk-7u80-linux-x64.tar.gz?AuthParam=1511124096_835cdc26cbf72802dd13c280b505542e
HTTP request sent, awaiting response... 404 Not Found
2017-11-19 21:39:38 ERROR 404: Not Found.
download failed
Oracle JDK 7 is NOT installed.
dpkg: error processing package oracle-java7-installer (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Ubuntu server 16.04
download failed
Ubuntu server 16.04
We don't install java. Check it yourself.
Kann mir wer helfen? :-D Ich bin relativ neu mit Linux und kenne mich nicht so gut aus :-D
[○ENG]
Can someone help me? Im new to Linux and i dont know a lot about solving problems :-D
[○ENG]
Was für ein OS hast du?
Bzw. versuche mal manuell "systemctl daemon-reload"
Sobald ich morgen zuhause bin, versuche ich Es! Auf dem vServer ist Debian 8.9 installiert.
Edit: hab gerade mal den Befehl in Google eingegeben. Wenn ich es richtig verstanden habe, werden damit Änderungen an der Unit Datei übernommen. Der Installer bricht jedoch nach der Installation vom Ts3 Server ab. Sag zumindest danach aus. Kann man die Installation vom Server überspringen? Ich habe bereits einen laufenden Server.
Es wird kein Server installiert, sondern ein Client.
Wenn nicht schreibe mir eine PN, dann schau ich mir das ganze über Teamviewer an und kann, wenn nötig den Installer anpassen.
